WHATS BOGGING?
Old Jan 17, 2008 | 10:39 PM
GT_Stang's Avatar
GT_Stang
Default WHATS BOGGING?
Im not a manual car so dnt get it to know. thanks
Old Jan 17, 2008 | 10:42 PM
P Zero's Avatar
P Zero
Default RE: WHATS BOGGING?
WHen you get on the gas and the car feels "bogged" down. More technical explanation,a dip in your power curve.
-P.
Old Jan 18, 2008 | 08:44 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
[sm=WTFsgign.gif]
Old Jan 18, 2008 | 08:46 AM
noober's Avatar
noober
I think he means when you shift too early and your car barely moves from the gear it's in...
I dunno. I don't drive manuals... yet.
Old Jan 18, 2008 | 08:49 AM
P Zero's Avatar
P Zero
It usually happens when trying to launch at too low of an RPM. THe car kind of stumbles, or another term "falls on its face", then "kicks" in and goes.
-P.
Old Jan 18, 2008 | 08:58 AM
ink003's Avatar
ink003
ORIGINAL: GT_Stang
i'm not exactly sure what this sentence means, so your reason for asking is kinda unclear, but anyway the above explanation is a good one. basically, it's just when you shift into a higher gear at too low an rpm range, viz. going from 2nd to 4th at 1100rpms, or trying to launch in 3rd gear.
Old Jan 18, 2008 | 09:02 AM
torque_is_good's Avatar
torque_is_good
you experience with automatics. It's also commonly called lugging. If you are driving a manny and going 30mph in 4th gear and punch the gas, the car will "bog down". It won't jump and go. You must downshift. With autos, your cars like to go into the highest gear at as low of speed as possible so you too aren't in the power curve and your engines lug or are bogged down until you punch it, the computer figures out what you want and then downshifts the tranny.
On boats, you'll get this if you swing a prop with too mutch pitch or diameter
Old Jan 18, 2008 | 10:31 AM
157dB's Avatar
157dB
Cut & Paste Expert
Its a louisiania swamp thang that
can only be seen under a full moon
Old Jan 18, 2008 | 04:53 PM
GT_Stang's Avatar
GT_Stang
got , i know remember the feeling from when I drive manual's i just didnt know what it was called
Old Jan 18, 2008 | 05:16 PM
bmk's Avatar
bmk
me trying to launch <-- thats bogging down... ill rev it where i think its right and pop the clutch, my car will basically sound like its dying and then it just takes off. i heard some where it takes about .75 seconds off your 1/4time if you bog
