WHATS BOGGING?
"Its a louisiania swamp thang that
can only be seen under a full moon"
LOL....seriously though, it's best described as giving too much gas, for the speed you're going. E.G. 4th Gear 20 mph..floor the gas pedal, and it will feel like you're choking the engine.
Its what happens when I launch on Street Tires.
4000 rpm (roughly based on track prep)... Quick lift on clutch while going full throttle.
Screeeeechhh.... Hook... Bog... Go. 1.89 - 1.90.. 60'
You would know it if you saw it. The front end drops when it happens.
Any more rpm and I blow the tires off and any less and the bog gets worse.
Essentially its because the car is falling to 2500 rpm and it doesnt make near the power their it does at 3000+ rpm.
PS This isnt a true bog. A true bog is what happens when the shooters (accel pump shot) are to small on a bracket car.
Seanam
Oct 4, 2015 10:15 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
