What can cause brake screeching to come back after new pads?
RE: What can cause brake screeching to come back after new pads?
You didn' t mix any of that Red Loctite with the lube did you?Brake pad material has an effect on this also ceramics are usaully better to reduce brake squeal.
ORIGINAL: ohnoesaz
This is the first time I did the rear pads. I did the fronts thinking they were screeching, but turns out it was the rear.
yes, I used anti-screech lube. Maybe I'll just open up the calipers and lube them up again... I basically lubed up everything on the brakepad except the front (obviously). Should I be lubing up anything on the calipers?
bond007
08-26-2015 11:36 PM
