91 Octane help!
Old Jan 21, 2008 | 09:05 AM
rneely2111's Avatar
rneely2111
Default 91 Octane help!
I put 91 octane in my car, I thought I had a 91 tune but I don't. Will this mess up the engine, if I put the car back to stock? Or shold I put it on 87, 89, or 93 octane?
Old Jan 21, 2008 | 09:08 AM
hammeron's Avatar
hammeron
Default RE: 91 Octane help!
load a tune that has a lower number, then the
octane rating you can regularly purchase
Old Jan 21, 2008 | 09:09 AM
FenderParrothead's Avatar
FenderParrothead
I would install either your 87 or 89 tune (the latter for more performance). You probably could go back to stock without any problems (don't know what all you've done to your car), but those tunes, I'm assuming, are designed with more performance for your car in mind, so why not just use them?!?
Then on your next fill up, put in whatever octane you want and install the appropraite tune.
Old Jan 21, 2008 | 09:49 AM
Nuke's Avatar
Nuke
As long asthe octane in the tankis higher thanthat required by the tuneyou've loaded it's not a problem.
Old Jan 21, 2008 | 09:57 AM
06Redfire3V's Avatar
06Redfire3V
ORIGINAL: Nuke
+1 you will be fine. Only if you uploaded a 91 tune and put in say 87 octane then you would have a problem
msavoia23
12
Jul 7, 2018 12:08 PM
Big Al's 03
Sep 15, 2015 09:05 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Sandmanbjj
Aug 21, 2015 12:38 PM
dragman72
Aug 9, 2015 12:54 AM
