Octane booster
Old Sep 13, 2015 | 01:55 PM
Big Al's 03's Avatar
Big Al's 03
Default Octane booster
A quick question....Can I put 87 octane in my Mach 1 that calls for premium
gas if I add a bottle of 104 octane booster ?
Old Sep 13, 2015 | 03:57 PM
Z28KLR's Avatar
Z28KLR
You could probably get away with it, but I wouldn't make it a lifestyle. I assume that you bought fuel somewhere that was out of premium, or are anticipating the possibility?
The problem I have with these snake oil/octane boosters is, I have yet to see one that mentions on it's labeling the amount of points it increases octane by in a given amount of fuel. There's just a lot of misinformation about these sort of products (per their labeling and advertising) that is aimed right at the wallets of people who don't know better.
Old Sep 13, 2015 | 04:09 PM
AK_Kayaker's Avatar
AK_Kayaker
Also the price of the octane booster could easily be more than the difference between filling up with regular and premium, I mean really it's typically only a few buck more.
Old Sep 14, 2015 | 07:43 AM
Big Al's 03
That's what I was thinking...With the labeling and not enough information.
Thanks, Z28KLR.
Old Sep 14, 2015 | 07:45 AM
Big Al's 03
Thanks AK Kayaker.
Old Sep 15, 2015 | 09:05 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I called up the Valvoline oil tech support line one time and got hold of one of their engineering eggheads. I noticed that they had changed their rating so called to ask about that then got off the subject I called about and onto the question of octane and using the octane boosters. What he told me was don't waste your time with the "miracle in a bottle" octane boosters. He told me that if you want higher octane then buy higher octane.
I mentioned that our Sunoco station here in town sells high octane fuel for about 10.00 a gallon but that is cost prohibitive so I go out to the airport and buy their airplane fuel and mix it about 50/50 with the 93 octane in my fastback (healthy 351w). He said that buying the airplane fuel is fine but not to run 100% or even 50/50 on the street because there were no idling properties built into that fuel and at most run it 70/30 (70% pump gas & 30% airplane fuel).
His pearls o' wisdom had some merit to them because when I would run it 50/50 or higher it would idle like crap around town but when I got on it, it would run like a raped ape. Once I started following his advice on the mix I did indeed notice an improvement in the street manners while still providing a very noticeable performance boost over using the straight 93 octane swill.
uberstang1
Sep 21, 2015 09:04 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
FD725
Aug 11, 2015 03:43 AM
