New Whipple S/C Gen 2 is out
Just thought I would post some info I have on the new Whipple newer version Gen 2.
Whipple has now released a new TS for are cars, the S/C has newer lobes called generation 2 which aresaid to be more efficient and make more power, would presume that would be under the curve of course.This new unit alsoruns a different size pulley than the older Whipples, example he saidif you took the new gen pulley from the 10psi HO and ran it on the older Whipple you would be running 12 psi.
Pricinglooks similar to the older Whipples the Gen 2in High Polishis $6495.00 plus $145.00 shipped direct.
Of course I would recommed shopping price.
This S/C is now shipping so will be interesting to see some dyno sheets soon.
If anyonehas any more info/details on this newer Whipplewould like to hear it.
RE: New Whipple S/C Gen 2 is out
I just ordered mine from Jared at Lethal Performance with a 3.625" pulley and an Aeroforce Interceptor gauge. Should be here next week!
And its actually the other way around on the pullies. The 3.375" will produce 12psi on the new blower, hence the 3.625" I ordered to keep it at 10 psi with the Gen 2.
ORIGINAL: CataclysmGT
On the pulleys then its the other way around ok.
Do you plan on getting it on a dyno soon after install?
I did. We didn't know for sure if the new HO kit has a different pulley ro compensate for the increased flow, so we ordered the 3.625" anyway. Perhaps I'll end up with two of em!
