has anyone done cams?
I have stage 3 compcams and am at 345.9rwhp and 327.67rwtq, I did sacrifice a little bit down low. There is honestly no point in doing cams unless you have longtubes, so save your money if you want only cams.
-Jeff
-Jeff
I did comp IIIs and they sound nothing like the videos. I did pick up almost 38hp and 30ft lbs of torque tho. Worth the money----ehhh mayby. Would I do it again? Probably not. I lost about 2.5-3 avg mpg. Could partially be the tune, but the same guy tuned it before, so I atribute it to the cams. Pro Dyno in Charlotte, NC did the install/tuning btw.
I also did Comp Cams Stage III when I did my stroker build and ported heads. IMO, it's worth doing, particularly if there is some economy of scale when doing the heads at the same time. Figure around 35whp with just these cams.
ORIGINAL: 06elnr
so i could put long tubes on and cams and a tune and should get about 30hp? how much do cams cost on average?
junior04
Sep 28, 2015 10:53 AM
