what type oil??
I wouldn't trust the dealer to do oil changes, they always screwed up for me. Not putting enough oil, putting the wrong grade, not tightening the drain plug, etc.
Lots of folks here do it themselves.
For me I bring my cars to the jiffy lube around the corner and watch their every move with an eagle eye. I also bring my own oil and filter.
I've used Mobil1 on all my cars for the last 10 years and do the same on the Mustang. I use the Ford oil filter, which you can find at your dealership or walmart.
08mustanggt, here's a link to a DIY on the forum:
https://mustangforums.com/m_3065332/tm.htm
Invest in a set of ramps (I use Rhino Ramps. They have a very shallow grade so you don't scrape the chin spoiler) and a decent filter wrench and drain pan. And buy a LOT of paper towels. It CAN be messy sometimes but I like to give the underneath a good visual everytime I get underneath. The ramps are also handy for any exhaust work. The S197 is pretty easy to do exhaust work on as it's all slip-fit and clamps.
Personally I think this whole oiltype thing is just a vasty conspiracy by a union of the world's top oil companies, oil producing nations, and the German and Japanese automakers (see, it's WW II all over again) to fleece us from our money.
Does anyone actually see a difference in their cars when using regular oil as opposed to the more expensive 5w20 synthetic or sythnetic blend? Didn't think so.
That's why I just use cooking oil for my cars and I never change it, only fill it up when it gets low. I've never had any problems.
ORIGINAL: Qusus
I know man, I was just kidding. I use synthetics for the cars that need reccomend them, but only synthetic blend for my Mustang.
I've had my full synthetic oil sent it for testing once when I changed it at 9,800 miles and it came back as still good. Can't do that with the regular stuff.
The cookin' oil comment was supposed to be the giveaway ha...
But serioulsy, synthetic saves you time and protects your engine, especially on cold weather startups. No doubt about that.
ORIGINAL: Qusus
...synthetic saves you time and protects your engine, especially on cold weather startups. No doubt about that.
[sm=violin.gif]
ORIGINAL: Qusus
Name Brand Synthetic is usually good for double the drain interval.
A Premium Synthetic that meets specs such as M-B 229.5 will usually go triple.
As cheap as used oil analysis is these days its pretty easy to see the diffference.
In wear metals however you would be correct.
Most people are just as well off with conventional. They tend to change synthetic about twice as often as conventional requires.
There are no Non-Synthetic Blend 5W-20's to the best of my knowledge. It is theorectically possible but costs more to do it that way. The 5W-20 marketed as conventional usually has a less robust additive package.
