Trunk Leak!
Old Jan 28, 2008 | 03:24 PM
laxplayer1028's Avatar
laxplayer1028
Default Trunk Leak!
I noticed that my car smelled a little bit like mildew soI went and opened my trunk and theright side of the trunk liner (around the right wheel well) was soaking wet. I took out the turnk liner and the right side liner in the trunk and theres about an inch of water down in the wheel well. I have NO idea what this is from and it's only on the right side. Any ideas?? Any help would be appreciated
Old Jan 28, 2008 | 03:58 PM
GidyupGo's Avatar
GidyupGo
Default RE: Trunk Leak!
You're going to need to get it wet and see if you can find the leak. Maybe a small hole around the drain channel. Maybe a window leak.
Old Jan 28, 2008 | 04:16 PM
laxplayer1028
I ran the hose all around the seal on the trunk and there was nothing coming in. I feel like its coming from the right wheel well somewhere because thats the only place where the water is....well i think it splashes over to where the spare is too...but there is NONE on the left side
Old Jan 28, 2008 | 04:19 PM
GidyupGo's Avatar
GidyupGo
Get a good light in the trunk and look all around that side at the seam sealer. The caulking gunk that they use to close gaps in body panels.
Old Jan 28, 2008 | 04:21 PM
157dB's Avatar
157dB
Cut & Paste Expert
Put your heater on full blast with the outside air circ open
and close all the doors. Then get underneith and look for
air blowing out of the affected area. You might have to
block off the air outlets located in the trunk area around
the spot you found water. The trick is to pressurize the
cabin and look for air leaks around the area of water.
You might have lost one of the air outlet flapper valves
and thats your source of water.
Old Jan 28, 2008 | 07:23 PM
2cokeman's Avatar
2cokeman
How about the spoiler holes not sealed?
Old Jan 28, 2008 | 07:55 PM
Stoenr's Avatar
Stoenr
More burnouts to seal the wheel well!
Old Jan 28, 2008 | 07:58 PM
laxplayer1028
The spoiler holes are fine. AndI tried the burnout thing, no seal yet....
haha
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
