Anyone else with a squeaky shifter?
Old Feb 7, 2008 | 01:25 PM
apex18's Avatar
apex18
Default Anyone else with a squeaky shifter?
Everytime i shift, it squeaks, something down there needs some lube i guess, anyone else with this, simple fix?
Old Feb 7, 2008 | 01:27 PM
thewarmachine's Avatar
thewarmachine
Default RE: Anyone else with a squeaky shifter?
My stock shifter squeaked a little. I figured it was the rubber boot rubbing against something. It went away.
Old Feb 7, 2008 | 01:28 PM
acascianelli's Avatar
acascianelli
Mine creaks and squeaks when it's cold.
Old Feb 7, 2008 | 03:27 PM
157dB's Avatar
157dB
Cut & Paste Expert
Its the inside of the rubber boot under the leather boot.
The rubber boot rubs up against itself and squeeks
Some rubber lube will prevent this from happening.
Remove the shifter **** with a twisting motion.
Remove the trim holding the leather boot in place
by sliding it to the rear and lifting carefully.
Now you have access to the rubber boot sealing the
passengers compartment from the underside of the
stang. Apply rubberlubricant to the areas that are
rubbing together. You might even notice the rubber
dust that has formed under the shifter console.
This is indication that your rubber weatherboot has
been rubbing and squeeking.
Old Feb 7, 2008 | 03:43 PM
acascianelli
ORIGINAL: 157db
Thanks! I'm going to try that.
Old Feb 7, 2008 | 09:50 PM
apex18's Avatar
apex18
Thanks for the info, i'm gonna try it out....
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
degner122
Sep 16, 2015 07:09 AM
