PUTTERING OUT AT 5000RPMS
Old Feb 10, 2008 | 03:20 AM
SANANTONIO06GT's Avatar
SANANTONIO06GT
Default PUTTERING OUT AT 5000RPMS
WANT TO SEE IF ANYONE HAS AN ANSWER TO THIS. I AM GOING TO TAKE IT TO THE SHOP WERE I GOT IT TUNED AND SEE WHAT IS UP.
WHEN I AM COMING UP IN FIRST AND STOMPING ON IT, AROUND THE 5000 RANGE, THE CAR, I GUESS FEELS LIKE ITS PUTTERING, WANTING TO BACK FIRE. I ALSO NOTICED THAT I HAVE LOST THE PICK UP THAT I HAD AFTER I GOT IT TUNED. IT HAS BEEN ABOUT 2 MONTHS SINCE I GOT THE TUNE. I AM RUNNING THE 91 TUNE, BUT USE THE 89 OCTANE, SINCE THERE ISNT 91 AROUND SA. ANYONE HAVE IDEAS THAT THEY COULD SHARE WITH ME, BEFORE I TAKE IT TO THE SHOP.
THANKS
Old Feb 10, 2008 | 03:41 AM
blike's Avatar
blike
Default RE: PUTTERING OUT AT 5000RPMS
First thing I'd try is reloading the tune
Old Feb 10, 2008 | 09:41 AM
kenthicken's Avatar
kenthicken
Running a 91 tune with 89 gas is a VERY bad idea... you can seriously damage your engine. What is happening is, there is too much advance in your ignition for the fuel that you are running, so it is likely detonating. This will cause damage to your valves, which (in a worst case) can break and drop into your combustion chamber -- which means engine rebuild time.
Reload with an 89 tune if only 89 gas is available. Never run the 91 tune with 89 gas.
Old Feb 10, 2008 | 09:45 AM
Black05StangGT's Avatar
Black05StangGT
+1 you should not be running a higher octane tune than the octane you are running in your vehicle...
Old Feb 10, 2008 | 11:09 AM
sailing220's Avatar
sailing220
Running a lower octante than your tune calls for IS NOT okay.
Running a higher octane than your tune calls for IS okay.
Old Feb 11, 2008 | 01:10 AM
Gene K's Avatar
Gene K
If 89 octane is all you can get then use a 89 octane tune (unless you are at high altitude).
Check and make sure you dont have the out of gear limit set at 5000 rpm.
In these cars the SCT programs it will limit in gear rpm as well.
You have to rewire a switch on the clutch to get it to function correctly.
Old Feb 11, 2008 | 01:21 AM
ohnoesaz's Avatar
ohnoesaz
You wont notice a decrease in performance at all if you switch to an 89 tune from a 91 tune. Trust me. So do it. Running a lower octane than the engine is timed for is very very bad. You're making me cringe.
Old Feb 11, 2008 | 04:53 AM
CataclysmGT's Avatar
CataclysmGT
Puttering = sputtering by any chance? :P
Seriously though, you need to reload an 89 or 87 tune immediately.
JamaicanStang04
May 23, 2008 12:32 AM
Daisy2000
Sep 3, 2007 07:32 PM
JDWalton
24
Apr 21, 2007 06:34 PM
Droptop5.0
Dec 13, 2006 09:16 PM
bchataroo
Dec 11, 2006 02:11 PM
