2nd gear grinding.. never got help
Old Feb 11, 2008 | 04:11 AM
str8wick3d's Avatar
str8wick3d
Default 2nd gear grinding.. never got help
So basically "still" whenever I want to get on it and shift quickly into 2nd gear, it grinds going into the gear... never fails.. I figured maybe I wasnt pushing the clutch in far enough, or letting go of it to quickly... False.... I can hold my foot all the way on the clutch.. put it in 2nd and it will grind before I ever take my foot off the clutch at all.. Can anyone help me? Normal driving is fine.... but who does that all the time?
Old Feb 11, 2008 | 09:01 AM
ink003's Avatar
ink003
Default RE: 2nd gear grinding.. never got help
i was appalled the first time i drove my stang at how crappy the stock gearbox was. barring any true mechanical problems with yours, i would suggest buying an aftermarket one. there are many to choose from that folks here recommend. i have the pro 5.0, which i like a lot, but most who have the experience swear by the hurstor themgw.
Old Feb 11, 2008 | 03:41 PM
str8wick3d's Avatar
str8wick3d
So its my shifter?
Old Feb 11, 2008 | 04:45 PM
frd06GT's Avatar
frd06GT
Sounds like a synchronizer to me. That is an internal part of your transmission that matches or synchronizes the speed of two gears that are going to be meshed together. All 5 speedsin yourtrans have sychros. The ones that go bad are usually 2nd and or 3rd. They see most use and the hardest shifting. Just my .02
Old Feb 11, 2008 | 04:59 PM
NyFordTech's Avatar
NyFordTech
ORIGINAL: frd06GT
+1 or the shift fork is binding when going hard on it, if its fine when he goes easy it's prolly not the syncros and blocking rings. The TR3650 is a pretty strong unit, bring it to the dealer and tell them you want to go for a ride with the tech. 5yr 60,000 mile powertrain coverage
Old Feb 11, 2008 | 07:32 PM
str8wick3d's Avatar
str8wick3d
Could I need manual transmission fluid? it has been rather cold out.
Old Feb 11, 2008 | 08:05 PM
billyjo's Avatar
billyjo
A grinding noise is your syncros and if you have a stock shifter you could be not pushing on the rods that push the syro tabs correctly. An option is to get a short throw shifter that finds the gears easier. If you are still in warrenty bring it in and check. Good luck
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
