Spoiler Deleted (PICS) & A QUESTION.
Some quick pics i just took :/
Now heres the freakin' question...
How to remove this sticky icky stuff?! Ive put Goo Gone on it, let it sit for a bit, it becomes all soft and stuff, but what do you guys use to actually take it off? I tried using a credit card, that didnt work. I dont want to use a putty knife and risk scratching it. Someone told me alcohol would do the trick? Anyway.. any input is appreciated.
Heres the pic of the hideous tape.
RE: Spoiler Deleted (PICS) & A QUESTION.
I rubbed mine away with my fingers. It rolls up easy enough, a 5 minute job. Then I wiped the residual greasy residue with a bit of gas on a rag followed by a quick application of wax.
Get some 3M ADHESIVE REMOVER, spray it on, let it sit for about 1-2 minutes,,, then get a large flat head screw driver (or something similar) and wrap it with an old sock, then you can push/scrap that stuff right off...did both sides in under 10 minutes....goo gone didnt work too well
ORIGINAL: marcuskeeler
ORIGINAL:chays446
Fingers?! WOW. Hats off to you, im not even going to attempt that one.
It'll just roll up under your finger/thumb tips, it's NOT hard at all. Mine was 18 months old when I didit so it had time to set pretty good.....
Well honestlyI don't see the problem, especially for a small area such as the two spoiler joints.
