Windshield Washer Relocation?
Old Feb 18, 2008 | 08:48 PM
sailing220's Avatar
sailing220
Default Windshield Washer Relocation?
Are there any kits out there for this? It isn't the look of the nozzles that bothers me - those can stay for all I care - it's just that whenever i spray the fluid spills all over the hood. Is there at kit that can relocats the hoses near the wipers or something?
Old Feb 18, 2008 | 08:58 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Default RE: Windshield Washer Relocation?
I never use that stuff. easiest thing to do is just clean it with those wiper things when you fill up gas
Old Feb 18, 2008 | 09:04 PM
sailing220's Avatar
sailing220
How about when you're in MN and there is salt and sand and crap all over the road and you have to clean your windshield every 5 mins while driving?
Old Feb 18, 2008 | 09:53 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
I got the CDC relocation kit after I got my hood. I did not want to destroy my hood with the ugly nozzles so I got the kit. Did not like the way it sprayed so I found some nozzles from Ford for a factory look and fit. Part#'s for the nozzles is F87Z17603AA. You gotta get 2, obviously.
With some research I found these and a write up to install, if you dont want to buy the kit.
You just have to buy a tee and 5 or 6 feet of hose to make everything work. Not only does it work but its actually better than the stock Mustang's because the spray from the nozzles hit the windshield directly instead of flying over the top of the roof like the stock Mustangs do.
Install Procedure
1. Locate washer hose under the hood mat and cut it.
2. remove both wiper arms.
3. remove the hood cowl, lifts off.
4. Add a tee to the supply line.
5. Run the extra hose you bought from Auto Zone in the cowl trough.
6. Bring both hoses through the wiper arm openings of the cowl.
7. Put everything back on except the wiper arms.
8. Fish the hoses through the spring of the backside of the wiper arms, fill the casting pocket of the back side of the wiper arms with silicone, push the hose into the silicone filled pocket and secure with a zip tie until dry, its Okay to move on to step 9 and 10.
9. reattach the wiper arms.
10. Slip nozzles onto the wiper arm and cut hose to length and attach.
Old Feb 19, 2008 | 12:05 AM
08Eleanor's Avatar
08Eleanor
I have a Cervinis C-Series Hood washer relocation kit. I could send it to you if you pay for shipping. I am not sure how it works, its being done to my car right now, but I can inform you when its done.
jma2
Jul 10, 2023 01:00 AM
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Cavedawg
Sep 17, 2015 09:51 AM
