Std Radio, external power when turned on?
I'm still considering adding a power antenna (auto up when radio turned on, auto down when radio turned off) To have this feature I would need to locate a lead that gets power when the unit is powered on (and disconnects when unit shut off). I thought someone out here had identified this but I'll be darned if I can find that post or that I had saved this info. Not sure if Shaker is the same but I would prefer if someone who is familiar with the std radio could identify the lead if there is one. I could try to locate it but that looks to be a lot of trial and error in what is in a rather confined space. Thanks in advance to anyone who can claify this for me.
RE: Std Radio, external power when turned on?
I'll get pics of the std radio wiring and post them later today.
[IMG]local://upfiles/69445/7CED3507423446FD8BCBB81A85A2F8DA.jpg[/IMG]
[IMG]local://upfiles/69445/C80DFA47A9B942B48734ACBE5B93F020.jpg[/IMG]
ORIGINAL: 157db
Hi Fairlane,
I don't know if this will help. It may be that the power connector on the radio might be the same:
http://www.cherod.com/mustang/HowTo/Shaker500.pdf
pin 2 on the J1 connecor supplies power only when the radio is on. I tapped into the wire that connects to this pin for my amplified internal antenna.
ORIGINAL: odiaz
Hi Fairlane,
Hi Fairlane,
Once again, thanks for your help!!
I couldn't find one because I wanted to hook my amp turn on lead to it. I ended up settling for a switched power so when the car is on the amp is on even if the radio isn't. I installed a switch to turn off the amp manually. If you end up finding one, plz pm me.
That was for the Shaker 500 but I don't imagine it being different for the std one.
ORIGINAL: Aziraphale
Connector C290B on the back of the radio.
Pin # 4.
DarkGreen/Violet.
https://mustangforums.com/upfiles/69...1A85A2F8DA.jpg
Pin # 4.
DarkGreen/Violet.
ORIGINAL: 157db
Pin # 4.
DarkGreen/Violet.
Pin # 4.
DarkGreen/Violet.
