How To: Stereo Removal?
I just took a quick look at TacoBill's How-To section ... and didn't see it there.
Does anyone have a walk-thru w/ pic on how to remove the factory stereo? (Shaker 500 and/or 1000)
-thanks-
-thanks-
Openn center console armrest.
Remove two screws at the back.
Remove shift ****.
Pull ebrake up.
Yank on console, starting at back, moving towards front. It'll pop off.
Yank on side center stack trim pieces, they pop off.
Remove 6 screws that hold the black plastic bezel on.
Undo the plugs for 12V socket, hazards, and reset/info (if IUP equipped)
Undo plugs for heater stuff
Remove four screws that hold in radio.
Reverse to reinstall.
Take about 15 minutes.
Remove shift ****.
Pull ebrake up.
What he said. It is straight forward. Not hard at all. The HVAC control conection is a little different, look at it from the side and find a grey lever. Flip the lever down, it will release!
Be careful not to brake the little gray lever as they are pretty weak. I broke mine while trying to get it off but luckily enough stayed on so I could still reengage them when reassembling the stereo.
Use this Taco Bill walk-through for the removal:
http://forums.bradbarnett.net/showthread.php?t=58114
ORIGINAL: rmssch89
Be careful not to brake the little gray lever as they are pretty weak. I broke mine while trying to get it off but luckily enough stayed on so I could still reengage when reassembling the stereo.
USE THESE LINKS, THEY ARE VERY DETAILED AND HELPFUL
http://www.2005stang.com/gallery/alb...nt%20panel.pdf
http://www.2005stang.com/gallery/alb...ceterpanel.pdf
http://www.2005stang.com/gallery/alb...81/console.pdf
http://www.2005stang.com/gallery/alb...adioremove.pdf
Read them all in detail as some console parts need to come off before you can remove radio/access the bolts. Good luck.
Thanks everyone ... looks like I'll be putting my Kenwood head unit, and Sirius tuner in on my days off.
Guess I need to get a dash kit and wiring harness -- any suggestions on where to get them?
-thanks again-
-thanks again-
