D-Specs & Springs finally installed..PICS.
WellI finally got the D-specs and BMR springs installed, man what a difference.
Springs drop F 1.25" / R 1.75", I have the dampers set to the 3 full turns back from full hard.
The car handles much more neutral now, with the drop, the relo brackets and LCAs it just digs and gets.
The rear axle is dead center of the car and hitting 2nd there is very little kick out.
I still need a new sway bar and to get the UCA assembly replaced, but Ifigured I could wait on that,I want to see the drop.
RE: D-Specs & Springs finally installed..PICS.
Warmachine do you have any bigger pics of the drop on your Roush setup?
I ask this because I drive my the Ford dealer every day with the Roush's out front and some look like they have a bigger drop then the others.
Thanks for the kind words.
Sure do! Here's the thread I made when I had them installed.
https://mustangforums.com/m_4485596/tm.htm
The pics were taken the day after the installation. I think they've settled some because now it looks a little lower.
^^^You sure can, but something tells me yours is faster, LOL.
Warmachine it looks real good, yours still has the forward rake to it which also looks good compaired to being leveled out.
i wonder if mine will settle some more and drop even lower.
