Does my Panbar look right????
#22
RE: Does my Panbar look right????
ORIGINAL: davesiar
That'll buff right out!!
on the plus side, i think its supposed to warm up around here soon. hopefully no more icy roads.
#24
That's a cool new innovation in Panhard rods. Notice how the mass of the rod has been lowered due to the bending.... It lowers your center of gravity! Great mod!
#28
Did you ever notice after hitting the curb that your rear tires were way off center with your wheel wells.The rear end would have shifted over to the passenger side.If you notice in your picture on the left side your sway bar has moved over to the right also because the bar is showing a fresh rust spot where it would have been contained in the rubber bushing of the sway bar mounting link.I would definately look over everything to see what else could bebent or damaged.
#30
I hit it hard. I did notice that the rear end is out of alignment. I assumed that that panbar was a little bent but I didn’t expect this. The rear end moved when I remove the drive side LCA, so the sway bar may have moved then. I had a hard time putting LCA back in, I had to use my legs and had a friend put in the bolt.
I Think I going to order an BMR ADJ panbar tommorrow or should I go with a Non adj?
