Sponsored by:
Sponsored by:
OCTANE BOOSTER PROBLEM
Old 03-06-2008, 07:01 PM
  #21
howarmat
s197 Junkie
howarmat's Avatar
Default RE: OCTANE BOOSTER PROBLEM
because we have tunes for 93 oct?
howarmat is offline
Old 03-06-2008, 07:09 PM
  #22
GidyupGo
GidyupGo's Avatar
ORIGINAL: noonyb
Fifth Gear a car show on BBC actually did a test of octane boosters. They found that all of the ones they tested actually caused a 2% loss of power. The tests were run on an engine on a dyno using exact measuments of gas and additives all giving the same results.
Higher octane pump gas has less power than lower octane. Don't know why the additive lowered your time though.
GidyupGo is offline
Old 03-06-2008, 07:51 PM
  #23
Meangreen1200
Meangreen1200's Avatar
ORIGINAL: howarmat
Thats why I said 93 plus=More than 93. Sorry if that was confusing. You should be able to get 93 octane at the pump.
Meangreen1200 is offline
Old 03-06-2008, 07:58 PM
  #24
howarmat
s197 Junkie
howarmat's Avatar
got you....my bad....you might be able to get 94 at some places but you are right, no reason to artificially inflate the 93
howarmat is offline
Old 03-06-2008, 09:25 PM
  #25
Allstar
Allstar's Avatar
new plugiesss r ur friend
Allstar is offline
Old 03-07-2008, 06:08 AM
  #26
EricM
EricM's Avatar
He can probably clean the plugs if they're just fouled.
EricM is offline
Old 03-07-2008, 08:33 AM
  #27
Feng Houzi
Feng Houzi's Avatar
true... make sure to put them back together after they crumble to pieces and you fish them outta the cylinder, then clean them, then re-install them...
Feng Houzi is offline
Old 03-07-2008, 09:17 AM
  #28
HaneyMotorsport.Com
Banned
HaneyMotorsport.Com's Avatar
I have seen this a few times. For some reason these engines Don't like it [:'(] It doesn't matter if it is n/a or f/i.
"Higher octane pump gas has less power than lower octane."
Not really true. Basically, the higher the octane, the slower burn rate. This is due to closer / denser packed fuel molecules. It takes longer time for a complete burn. This is why running higher octane than needed usually makes less power. The way to make more power is to advance the timing to start the burn process sooner for the higher octane.
Casey
HaneyMotorsport.Com is offline
Old 03-07-2008, 09:30 AM
  #29
GidyupGo
GidyupGo's Avatar
ORIGINAL: HaneyMotorsport.Com
Casey
To put it in layman's terms, slower burning fuel makes less power. That was the point I was making which you backed me up on.
GidyupGo is offline
Old 03-07-2008, 09:43 AM
  #30
HaneyMotorsport.Com
Banned
Oh, I got what you were saying now. It doesn't read that way.
Casey
Quick Reply: OCTANE BOOSTER PROBLEM
