Autometer guage lighting connection??
Old Mar 5, 2008 | 09:35 PM
eric6913's Avatar
eric6913
Default Autometer guage lighting connection??
hello,
where did you hook the guages up to? where and which wire did you use for the lighting? do the guages dimm with the rest of the dash? any info is appreciated. thanks.
Old Mar 5, 2008 | 10:18 PM
GTstangB.F.D.M.'s Avatar
GTstangB.F.D.M.
Default RE: Autometer guage lighting connection??
hey man..
i did this with mine.. but becareul.. i have to re-do it now, bc they only work when my headlights/parking lights are on.. if they are not on.. no power gets to the gauges.. so i have to figure out hwere i went wrong..
as far as where to hook up for the dim thing..
take that switch pannel that holds the dimmer and the light switch.. you will see a plug that has like 8-13 pins/wires.. the wire you want to tap for the dim, is i believe, the yellow wire with purple line.. or the second from the right pin..
heres a pic of when i did mine..
.... you know what.. i think i know where i went wrong...
im going to take a look at this and get back to you in the next day or two.. it will probably be too late... but also, here is a write up from someone else..
http://www.users.qwest.net/~cookpagi...augePower.html
i know where i went wrong.. i put both, power and back light to the head light switch, where the power should be connected to something thats hot when the key is on, and the backlight to when the headlights are on...
i am gunna finally fix this crap once and for all..
Old Mar 6, 2008 | 11:05 AM
eric6913's Avatar
eric6913
bump
Old Mar 6, 2008 | 01:31 PM
NVRL8's Avatar
NVRL8
Or you can follow this thread, this is how I have mine https://mustangforums.com/m_4172896/...tm.htm#4173916
Old May 3, 2008 | 11:34 AM
MTAS's Avatar
MTAS
ORIGINAL: GTstangB.F.D.M.
hey man..
http://www.users.qwest.net/~cookpaging/bumbleboost/GaugePower.html
This worked like a charm - thanks!
trashxtrash
Sep 20, 2015 10:49 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
96stang3.8
Sep 10, 2015 06:42 AM
