Cervini Scoops Installed... Possible Problem... HELP!!!
Old Mar 7, 2008 | 09:55 AM
Boozshey's Avatar
Boozshey
Default Cervini Scoops Installed... Possible Problem... HELP!!!
So I installed these things this morning. Had them for a while now and just waiting for some higher temps. Well it's 77* and decided to install them. But I didn't check the forcast... OOPS... So I was watching TV and they said it might rain later...
Is this going to be a problem... The instructions said to let sit for 24 hours. But is that a real time or just a lets play it safe time?
Old Mar 7, 2008 | 10:02 AM
ink003's Avatar
ink003
Default RE: Cervini Scoops Installed... Possible Problem... HELP!!!
well, you will probably be ok, but i might try to cover them up with a tarp or something. you definitely don't want water getting in there and compromising the integrity of the adhesive.
Old Mar 7, 2008 | 10:12 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Get a ziplock bag or some kind of plastic and painters tape and tape it over the top of the scoop so the water runs off of it and not down behind it.
Old Mar 7, 2008 | 10:17 AM
SaddleUp's Avatar
SaddleUp
I really think you're fine....if you used the same stuff to install your scoops that came with mine?
They won't come off in a damn tornado!!! I wouldn't worry, you installed them in good temps. I bet you could take a waterhose to them and hang off of them, they aren't coming off!
congrats, btw........[&:] s ~
Old Mar 7, 2008 | 10:33 AM
157dB's Avatar
157dB
Cut & Paste Expert
The 3M acrylic adhesive is waterproof and its fine from
the minute they are stuck on for water to get on them.
Unless you used Elmers glue to install them.
Old Mar 7, 2008 | 11:49 AM
Boozshey's Avatar
Boozshey
Well its 3m from advance auto parts...
Old Mar 7, 2008 | 11:57 AM
300GT's Avatar
300GT
you ever tried to remove something stuck on with that3M stuff- it's like it's welded on. I wouldn't worry one bit if I were you.
Old Mar 7, 2008 | 01:03 PM
Boozshey's Avatar
Boozshey
Sounds good... The car looks so hot!! Not that it never did... I will get pics once the weather gets better, nothing is worse than washing a car and then it raining.
Old Mar 7, 2008 | 01:18 PM
Boozshey's Avatar
Boozshey
ORIGINAL: SaddleUp
Well that's actually a relief seeing how the TV just flashed and said there is a Tornado Warning for the next hour!!!
I HATE MY LUCK!!!!!
Old Mar 7, 2008 | 01:35 PM
okbfd's Avatar
okbfd
LOL......gotta love the timing. Get some picks.....love those scoops.
