Grille pics
Old Mar 10, 2008 | 03:42 PM
  #41
redhot06's Avatar
redhot06
Default RE: Grille pics
With fogs!
Old Mar 10, 2008 | 03:59 PM
  #42
05MustangSally's Avatar
05MustangSally
Personally, I don't like the fogs in the grille. But if you're going no fogs...definitely get something different grille-wise. Otherwise, it looks just like a stock V6. I'm planning on getting a black billett grille for mine until I get the money to do the GT500 front conversion. I like fog lights at the bottom of the fascia...works better in the fog too
Old Mar 10, 2008 | 04:05 PM
  #43
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: TJ
Ok I just went out and checked the tires you guys (thewarmachine)are right I never noticed!
I will have to switch the right front to the left front.
Thanks
Its not side to side that looks funny, its front to rear.
Are you running staggered fitment rims/tires?
The front tire/rim looks bigger than the rear tire/rim.
[IMG]local://upfiles/69445/46408CA3FA6440D791B72A871A1D5E21.jpg[/IMG]
Old Mar 10, 2008 | 04:11 PM
  #44
TJ's Avatar
TJ
ORIGINAL: 157db
ORIGINAL: TJ
Thanks
157b the rears are oncorrectly,the front right needs to be on the left front and the left front needs to be on the right front that is the problem they just need to be switched. I had them off and when I put them back on I didn't put them on correctly. Once I switch them they will be on correctly.
Old Mar 10, 2008 | 04:15 PM
  #45
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: TJ
ORIGINAL: 157db
ORIGINAL: TJ
Thanks
Ahhh Paralax error...
I see, the tread is not pointing the same way.
So no staggared fitment? Tires/rims the same size
front and back? What ya running size wize?
Old Mar 10, 2008 | 04:26 PM
  #46
TJ's Avatar
TJ
I decided to stay with the fogs I'll think about a billet grille with fogs as I do like partsbill grille butmight just stay with the stock grille & fogs. I do kind of like it without the fogsbut like others said a blackbillet grille be the way to go if going that way.
I am going to get some black vinly circular inserts made up 1/2" to maybe 1" to give the fog lights a little smaller apperance just to see what that looks like, if it looks decent I will post a picture.
In the photo below I removed the turn signals per PS now that I like no doubt!
Old Mar 10, 2008 | 04:44 PM
  #47
TJ's Avatar
TJ
ORIGINAL: 157db
I am running AM 18x9 w/255-45-18's all around.
jhawkr
Oct 30, 2015 01:55 PM
9550
Oct 26, 2015 05:01 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
tmdm
Sep 18, 2015 03:10 PM
