Lowering Plan
Old Mar 12, 2008 | 10:32 PM
Be Rad 13's Avatar
Be Rad 13
Default Lowering Plan
I just ordered Roush front and rear springs anda matching pair of roush shocks along with a set of Camber Bolts. I found a sweet deal on the springs on Ebay, which was sweet.
Do you think it would also be wise to order a set of Roush struts, or will the stock GT struts be okay with the Roush front springs? Also, would it be a good idea to install an adjustable panhard bar as well, or is it really not needed with only a 1" drop with the Roush rear springs?
Any thoughts you might have based on your experience with lowering and suspension would be great!
Old Mar 12, 2008 | 11:07 PM
Burnsy's Avatar
Burnsy
Default RE: Lowering Plan
yes an adj. panhard bar would be a good idea
here is a great write-up, it is long, but a worth-while read:
[quote]ORIGINAL: CrazyAl
The FRPP pack is OK I suppose. It's not the best, and it's not what I would call cheap, but it's alright if you don't want to do your homework.
Here are my more detailed thoughts on the more commonly discussed suspension upgrades:
Sway Bars:
The front is quite good stock. There are many, many, things that I would replace before the front sway bar. In fact, I'd put the front sway bar at the very bottom of the "suspension mod list". The rear, however, is an excellent thing to upgrade. A stiffer rear bar will help keep both tires planted when you hit the gas on the strip or coming out of a corner. It will also balance out the steering bias (understeer) the car has from the factory. I like the Steeda and the BMR ones the best, but there are many choices here: Steeda, BMR, Ford, Roush, Eibach, etc. I left my front stock and got a Steeda rear--I normally don't like Steeda's billet aluminum parts, but their rear sway bar with the billet mounting bars is a great product. The billet bars are much stronger than the flimsy OEM ones. Another option would be to find a Shelby rear sway bar, as Ford increased the size of the rear bar on the GT500. Several companies sell a kit that has both front and rear sway bars. Personally I do not like these. I would stick with the rear ONLY. Stiffening the front istypically a DOWNGRADE because it will prevent you from eliminating the oversteer problem.
Al's Pick: Leave the front stock. Either Steeda or BMR rear.
Strut tower bars:
The theory of this product is that it ties together the front strut towers, reducing body flex. The S197 chassis is very stiff--espeically at the front strut towers. Consequently this isn't really needed. In my opinion, this is a mainly costmetic mod. There are tons of choices out there as this is a popular "me too" product that was popularized with ricers--becasue of this there's flood of them on the market. The the BMR is the strongest. If you seriously want one that's functional, that's what I'd get. The Steeda one with the billet ends is a joke and has an insane price tag. No thanks! Note that some strut tower bars can interfere with superchargers or plenum covers, so be careful of that.
Al's Pick: none. leave it stock and save your $$$ and weight for mods that really count.
Shocks:
If you want good shocks there are many options: FRPP and Saleen are a good match with lowering springs. But, the hot ticket is the Toicko D-specs. These are fully adjustable, so you can set up your car for street, road race, drag, or whatever you feel like. They also have very good valving, which was designed in part by Steeda. You can adjust them very quickly (less than 5 min for all 4 shocks), which gives you a lot of options. If you have to take a long trip with the family you can soften 'em up and make the car ride like a cadillac. Stiffen up all four when you drive in the twisties. You can leave the rear stiff and soften the front for better transfer on launch when you hit the drag strip....these are just some examples, but suffice it to say the D-specs are very very nice. Check with Brenspeed for the best price that I know of. Last time I checked they were $540 for all four, with free shipping!
Al's Pick: D-specs.
Springs:
Many choices here. Springs are mainly a cosmetic thing, but a mild drop will lower the center of gravity of the car and that can help cornering. All of the major brands are good (Eibach, Ford, Steeda, Roush, BMR). I'd make a choice depending on how much lowering you want. The most popular for mild drops are the Roush and the Steela "ultralite" springs. The Eibach Pro-Kit is really popular too. Roush will sell you sets of just fronts or just rears. Some guys, myself included, lowered just the rear of the car. I think that's nice if you want a very mild drop and you want to be careful about ground clearance. Beware the Eibach "sportline" kit. This is a VERY low drop that is impractical on a street-driven car, and is sure to cause headaches with alignment, bump-steer, etc. I would only consider the sportlines if you want a "Show" car and don't plan on driving it hard.
Al's Pick: any major brand
Coil Overs:
If you want, you can replace the stock shocks and springs with a coil over setup. Coil-overs combine springs and shocks into a single package. They are usually adjustable for both ride height and for damping (like the D-specs). These are very expensive, but have the advantage of letting you adjust the ride height exactly where you want it. I wouldn't buy these unless you are a very serious road-course racer and need to get everything absoloutley perfect. They are a pain to adjust, and then once you have the height set where you want it, then you have to go and reset the camber, pinion angle, and all that. You can't practically adjust your ride height to suit your whims, there is just too much work involved.
Al's Pick: Not worthwhile. Your money is better spent elsewhere. Stick with a good set of traditional shocks and springs.
Lower Control arms (LCA):
This is a key weak point from the factory. I consider this a MANDATORY mod for all S197 Mustang GTs. If you're tired of wheelhop, wasted HP and loss of traction then this is the first mod you need to do. I like the tubular welded steel ones, such as those from Spohn, BMR, CHE, etc. There are different types available (adjustable vs. non-adjustable). Get the adjustable ones if you have lowered your car (or if you have a 1-pc driveshaft) so that you can correct your pinion angle. Get the solid ones if you aren't lowering the car and are not going to get a 1-pc driveshaft. Steeda makes some billet aluminum ones which look nice but are $$$ expensive and are known to break on high HP cars. I'd avoid those and get the tubular steel type. The tubular steel ones are lighter, stronger, and cheaper. I don't like the CHE ones becasue they don't have grease fittings in them. That's bad for maintenance. My favorites are the BMR "combo street" type with a poly bushing on one end and a spherical bearing on the other. Spohn has a set that is virtually identical, either would be a fantastic choice.
Al's Pick: BMR or Spohn "combo" type. Adjustable if you are lowering or have a 1-pc driveshaft. Solid for stock height & driveshaft.
Upper Control arms (UCA):
Another factory weak spot. The upper control arm is located above the rear differential housing. The stock one is stamped steel and is quite flimsy for the amount of load it has to bear. You can get aftermarket UCAs in either the solid type or the adjustable type, just like LCAs. You only need adjustability on one set (either upper OR lower). Personally I suggest a SOLID UCA and then adjustable LCAs. (this is stronger and easier to adjust). I think the BMR solid UCA is the best on the market, no contest. While many companies have decent LCAs, BMR is the undisputed king of the UCA. It's boxed design and thick steel construction is completely bulletproof. I suggest the one with the spherical bearing. Also, buy a polyurethane bushing that fits in the diff housing to go with it. The bushing is dirt cheap, and it's a pain to install. But it's worth it. This combined with good LCAs will have your rear end hooking up like nobody's business. If you are running serious HP and low drag times, get the matching UCA mount to go with this. The poly bushing for the rear end housing is available from Spohn or BMR.
Al's Pick: BMR solid (non-adjustable) with spherical bearing.
UCA Mount:
This is a metal bracket that bolts to the unibody. It's job is to hold the forward end of
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
