soundproofing doors
soundproofing doors
Got some Damplifier yesterday, (cheaper than Dynamat) and gonna start soundproofing this weekend. When soundproofing the doors, should I lay the soundproofing to the inside of the outide door skin (if I can get to it), or to the sheet metal inside the door. I would think the sheet metal inside the door, on theinteriorside, but I'm not sure if everything will fit back together unless I put it on the exterior side of the sheet metal. Ithink it's gonna be pretty difficult to get toeither theexterior sideof the sheet metal or the interior side of the outer skin.
Anyideas would be appreciated. I haven't started yet, so just trying to get some ideas before I get my door apart.
RE: soundproofing doors
Get spray on soundproofing for the outer door skin.
Thedoor panelswont fit back on if you put it on the face
of the interior skin under the door panels.
Pic
[IMG]local://upfiles/69445/85D52482FAE942C88FCA9A4237179218.jpg[/IMG]
Pic
You should be able to have some access to the outer door skin with the window rolled up. I don't know if adding sound proofing material to that is going to make that much difference.
both sides heres the pics of mine.
I used damplifier as well. Your doors are gonna be solid as hell I would focus more on that plastic door panel because well thats where all the crap is anyways. If you like fiberglass, glass the inside of the abs enclosure. Thats what I will be doing next but i hate fiberglass....
+1 to the spray over the mat on your doors. After about 4 years in my previous car, the car was outside all day on a very hot sunny day and it caused the dynamat to flap down a little bit. Long story short, rolled down the window, flap stuck to it, Flap came sticking out on my glass and F'ed up my glass, window alignment, and motor. Id say the mat is fine for the floor but I would only do spray on doors now just because you dont ever want to have to deal with that. Only takes 1 little piece to come off for it to happen, even if the rest of them stayed down
Ideally you want to do multipile layers of deadening on the inside and outside of the door, and the door panels as well. Be sure to at least have multiple layers on the outer door skin directly behind the door subs. There's a great how to article on adding sound deadening on here, it's in the big sticky that lists all of the how to articles. Dunno if you've seen it before, but it's very helpful.
Hope this helps a little bit.
ORIGINAL: lrgnation
I'm done. I only did the inside of the outer skin because the inner sheet metal just doesn't have a lot of area. I also did the whole trunk (not the lid) and under the back seats.
BIG difference. The stereo sounds much better and there the car is much quieter.
Only problem, I can't hear my mufflers anymore.
Not that hard to do the doors panels. Just do a search. Leave the windows up so you can access the outer skin. Pull up the bottom half of the moisture barrier and you will be able to do the whole door.
ORIGINAL: CrazyHorse0217
That's fine.. everyone else still can!
