Strange Vibes
I need some serious help with this one....
There's a strange vibration that is only felt in the shifter and by putting my hand on the engine or exhaust pipes. I don't feel this vibration in the pedals or the steering wheel.
1) The car idles smooth, but has a vibration (like a cell phone) felt in the shifter with a random thumping pulse every second or two. I checked vacuum at idle and it's steady at 24" hg.
2) The vibration and random thump felt in the shifter while driving gets a bit more intense as load increases. It happens in all gears, at all speeds, as well as zero speed at idle.
3) When crusing at a steady speed (usually on the highway) The vibration will "sometimes" start to oscillate, or make like a wave feeling. It's the same constant vibration, but it gets more intense and then less intense every 2-3 seconds. This is the most puzzling to me, since nothing at 70+ mph is rotating every 2-3 seconds.
Things I have checked....
1) All exhaust mounts, clamps, pipes, clearances and bolts, including manifolds.
2) Pulleys with belt removed.
3) Engine vacuum at idle.
4) Pulled plug wires (one at a time) to verify missing cylinders.
5) Pulled fuel injector wires (one at a time) to verify missing cylinders.
ORIGINAL: PLstang
Is it visible when you watch the engine? Could you have a bad plug? It kind of sounds like a dead hole. Mine did that once and I found a plug that was bad when I pulled them.
When I pull the plug wires, one at a time while idling, I hear a distinct miss and it recovers a few seconds after plugging it back in.
I'm not ruling out a miss, but with no codes, and the plugs looking good, it's hard to say.
I have to ruleout anything past the flywheel, because it can be felt with the clutch pushed to the floor inneutral, although it's much fainter. Gets much more pronounced as load increases. The thumping or pulsing on top of the vibration gets really bad under heavy load and lowerRPM's.
ORIGINAL: PLstang
ORIGINAL: GidyupGo
Engine harmonics. Could be the ballancer or any number of other components.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MustangVixenGT
Sep 16, 2015 04:16 PM
