program OEM remotes to system?
Old Mar 19, 2008 | 11:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: program OEM remotes to system?
the part i have a problem with is i cannot electronically unlock it. i put in the SJB from the wrecked 07 and do not have a remote for that SJB...so I cannot get it into programming mode. do you know if the remotes are the same from a non active alarm car to an active alarm car?
thanks
According to the dealer you dont need to remotely
unlock the vehicle with a remote fob.
EDIT AFTER RESEARCHING THE WORKSHOP MANUAL FULLY:
OK, here is what the Ford Workshop Manual states in section
501-14-30 Handles, Locks, Latches, and Entry Systems:
http://iihs.net/fsm/?dir=465&viewfil...rogramming.pdf
1. The vehicle must be electronically unlocked before entering program mode,
via the RKE transmitter or the door lock control switch while the drivers door is open.
2. Turn the key from the OFF to the RUN position 8 times within 10 seconds, with
the eighth turn ending in the RUN position. If the module has successfully entered
program mode, it locks then unlocks all the doors.
And so on...
Keep me advised as to how you eventually get er done.
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
winner99
Oct 1, 2015 10:52 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
