program OEM remotes to system?
Old Mar 18, 2008 | 08:14 PM
hotairgypsy's Avatar
hotairgypsy
Default program OEM remotes to system?
Well i swapped the smart junction box and need to program in my remotes. I know the procedure if i could electronically unlock the car but in this case was not an option.
SOO how do i program them in so i can unlock/lock etc?
Old Mar 18, 2008 | 09:38 PM
hammeron's Avatar
hammeron
Default RE: program OEM remotes to system?
i think we need db on this one
Old Mar 18, 2008 | 09:48 PM
hotairgypsy
db? i am a bit retarded right now...lack of sleep..i have a screaming 8 month old
Old Mar 18, 2008 | 09:51 PM
ajaibr's Avatar
ajaibr
Check this thread... IDK if it covers the problem you're having or not...
https://mustangforums.com/m_4746242/tm.htm
Old Mar 18, 2008 | 09:56 PM
hotairgypsy
That would work if i had a remote code already in the SJB but I do not. This PCM came out of the wrecked 07 GT and I didnt get any remotes with the car. So i have to program in my original remotes from my 05 GT.
Old Mar 18, 2008 | 11:03 PM
hammeron's Avatar
hammeron
gypsy, if this can be solved, 157db would
be the one to solve it.....maybe he'll see this
thread in the next day or two
Old Mar 19, 2008 | 08:52 AM
hotairgypsy
now where is the ol 157db...come out and play!!!
Old Mar 19, 2008 | 09:10 AM
GidyupGo's Avatar
GidyupGo
Patience. He'll be here. Could PM him.
Old Mar 19, 2008 | 09:25 AM
hotairgypsy
that would be too simple wouldn't it
Old Mar 19, 2008 | 10:52 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: hotairgypsy
OK, here I am.
When you program the remotes as per the owners manual,
you must have all the remotes even previously programmed one.
When you go into the programming mode, all previously remotes
are unlearned and you must learn all the new ones AND old ones to
the SJB. So I only see the need to go into programming remotes mode
and teach the new SJB your remotes codes.
Am I missing something here? Did I not understand the
question of the OP right?
COPIED FROM ANOTHER POST:[align=left]How to reprogram your remote entry transmitters[/align][align=left]You must have all remote entry transmitters (maximum of six)[/align][align=left]available before beginning this procedure.[/align][align=left][/align][align=left]Note: Ensure the brake pedal is not[/align][align=left]depressed during this sequence.[/align][align=left]To reprogram the remote entry[/align][align=left]transmitters:[/align][align=left]1. Ensure the vehicle is[/align][align=left]electronically unlocked.[/align][align=left]2. Put the key in the ignition.[/align][align=left]3. Cycle eight times rapidly (within[/align][align=left]10 seconds) between the 1[/align][align=left](OFF/LOCK) position and 3 (ON).[/align][align=left]Note: The eighth turn must end in the 3 (ON) position. The doors will[/align][align=left]lock, then unlock, to confirm that the programming mode has been[/align][align=left]activated.[/align][align=left]4. Within 20 seconds press any button on the remote entry transmitter.[/align][align=left]Note: If more than 20 seconds have passed you will need to start the[/align][align=left]procedure over again. The doors will lock, then unlock, to confirm that[/align][align=left]this remote entry transmitter has been programmed.[/align][align=left]5. Repeat Step 4 to program each additional remote entry transmitter.[/align][align=left]6. Turn the ignition to the 1 (OFF/LOCK) position after you have[/align][align=left]finished programming all of the remote entry transmitters. Note: After[/align][align=left]20 seconds, you will automatically exit the programming mode. The[/align][align=left]doors will lock, then unlock, to confirm that the programming mode has[/align][align=left]been exited.[/align]
