fault code??? help!!
Old Mar 19, 2008 | 04:42 PM
07vbluestang's Avatar
07vbluestang
Default fault code??? help!!
my car seemed pretty quick when i bought it and then after 658 miles i got a check engine lite!!! took it to the dealer and had it checked!! here is what the work order says!! fault code p0171 in systemperformed ECC TEST AND DRIVEABILITY TEST-KOEO, RETRIEVED FAULT CODE P0171, BANK 1 SENSOR ,LEAN FAULT, MONITERED SENSORS, FAULT IS NOT ACTIVE, RAN OASIS, NO BULLETINS IN SYSTEM, CLEARED FAULTS AND TEST DROVE VEHICLE!! the car nevered seemed to be as quick as it once was before. is there something else can be wrong?
Old Mar 19, 2008 | 05:11 PM
acascianelli's Avatar
acascianelli
Default RE: fault code??? help!!
Any modifications? I had this code when I was running an bad tune for my setup. Check all the hoses on the intake.
Old Mar 19, 2008 | 05:25 PM
howarmat's Avatar
howarmat
s197 Junkie
o/r pipe
157dB's Avatar
157dB
Cut & Paste Expert
Try the adaptive learning reset procedure
and recalibrate your gas pedal.
Old Mar 19, 2008 | 06:03 PM
07vbluestang
at the time i had no mods, no x pipe!!! car was bone stock!!! what is adaptive learning reset procedure and recalibrate gas pedel.
Old Mar 20, 2008 | 06:46 PM
DeStonn's Avatar
DeStonn
What was the code people were throwing when the fuel cap needed to be tightened?
Old Mar 22, 2008 | 02:30 PM
07vbluestang
they ask me if i ran the fuel in the tank low!! they said about gas cap and it was o.k. too!!! there was 1/2 tank of gas in it!!! it's just never been the same since. oh well i probably am getting it supercharged anyway!!!
Old Mar 22, 2008 | 02:35 PM
DeStonn's Avatar
DeStonn
Plugs???
Old Mar 22, 2008 | 03:20 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: 07vbluestang
Adaptive learning reset by removing the negative nattery cable for 20 min or so.
Gas pedal reset is turning the key on, wait until the dash icons go out, press the
pedal all the way to the floor and then release it. Turn key off.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
