Pinion angle assistance please
Using CrazyAl's measuring technique (with the square), I came up with 87.5* at the tranny flange and a hair over 90* at the pinion flange. Assuming my math is correct (), this gives me close to 2.5* of negative pinion angle. Correct?
Now, CrazyAl's info suggests about 2* of negative pinion angle. BMR Fabrication's install instructions for the adjustable LCA suggest 2-3* on cars with manual transmissions. Should I leave my car at -2.5*, or get it closer to 2*??
thanks, mike
thanks, mike
RE: Pinion angle assistance please
That's kind of what I'm thinking. I just need to find an alignment shop that specailizes in it. I just want to make sure my rear axle is square and straight. It should be, I installed the LCA's again tonight; moved from lower hole to upper hole (on relo-brackets) and this time, I measured factory lengths (hole to hole) with my Mitutoyo dial calipers.......both adjustables are about .005 longer than the factory LCA.Man, Im a loser.....doing stupid math instead of tearing into my struts.
Maybe this will help.
http://www.steeda.com/directions/555...l-arm-s197.pdf
Steeda has a lot of good info on their site.
Ford manual compares front u joint angle to rear. Front is calculated by the flange angle - shaft angle (large number -small) the rear is shaft - pinion flange (large vs small).
These two calcultions must be = or within 1 degree, have a 3 degree maximum operating angle, and have a min of 0.5 degree operating angle (to avoid brinelling of the needle bearings)
So, looks like I should adjust mine a bit, since right now everything is at .... 0.
KingRando
10-02-2015 08:06 AM
