spohn LCA
Old Mar 22, 2008 | 09:59 AM
schapman's Avatar
schapman
Default spohn LCA
I just had the Spohn adjustable LCA and they are making noise after only one week, both end poly. How often do you have to grease these?
Old Mar 22, 2008 | 10:33 AM
leepinlen's Avatar
leepinlen
Default RE: spohn LCA
I have the same lca's, after changing ploy bushing, lubeing every week, checking the bolts, I finally removed and replaced with the stock ones and no more squeaks.
Old Mar 22, 2008 | 01:25 PM
Bluestar's Avatar
Bluestar
Note to Self.....Avoid the aforementioned LCA's
Old Mar 22, 2008 | 01:45 PM
johnpagenola's Avatar
johnpagenola
I had the poly/poly LCAs from Spohn made from Chrome/Moly. They are very light, very strong, and they control wheel hop great.
However, there is no way to keep them from making those noises (squeaks, squawks, whatever you want to call them).
I replaced them with GT500 LCAs. Result: no noise and no wheelhop.
But my engine is unmodified. The Spohn would probably be better than the GT500 LCAs for high horsepower applications, but that is not me.
Old Mar 22, 2008 | 02:04 PM
vtmustangs's Avatar
vtmustangs
This is interesting thread because I heard spohn was one of the better brands for lcas.
ORIGINAL: johnpagenola
Where did you get the gt500lcas?
Old Mar 22, 2008 | 02:25 PM
probinator's Avatar
probinator
I Dont think what anyone does to them will keep any of them from creeking or making noise. If you want a little better then stock. I would do the gt500 LCA.
I also have the spohn, and I like them.
Old Mar 22, 2008 | 02:33 PM
DeStonn's Avatar
DeStonn
I have the Spohn and yes they squeak but everything else on the car makes noise so it doesn't matter to me
Old Mar 22, 2008 | 03:11 PM
schapman's Avatar
schapman
I sure wish people would of said something in other posts before i purchase these. Most every other post praise the LCA and say they are needed. the only reason i purchase these was to adjust the pinion angle. if greasing them does fix it I may go back to stock or gt500 and say s%$#w the pinion angle.
Old Mar 22, 2008 | 03:58 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: vtmustangs
www.mossmustang.com
$139.95 WITH the Ford one-time-use hardware.
Its a steal at that price WITH the hardware.
http://www.mossmustang.com/Shop/View...eIndexID=57764
[IMG]local://upfiles/69445/8563CF100AEF470DB2509C3391486FED.jpg[/IMG]
[IMG]local://upfiles/69445/A3D8391BC76F41469E00AD06A7236EE2.jpg[/IMG]
Old Mar 22, 2008 | 04:17 PM
FlaPony's Avatar
FlaPony
e-bay has a set
http://cgi.ebay.com/ebaymotors/SHELB...em260221083369
