spohn LCA
Old Mar 22, 2008 | 04:34 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: spohn LCA
ORIGINAL: FlaPony
e-bay has a set
http://cgi.ebay.com/ebaymotors/SHELB...em260221083369
Yes, but no hardware to install them with.
The Ford hardware could cost as much as $60
so the ones fron moss mustang are a far better deal.
Unless you want to risk re-using the one-time-use fastners. []
Plus they are USED not new.
Old Mar 22, 2008 | 04:36 PM
vtmustangs's Avatar
vtmustangs
You shouldnt get the GT 500 LCAs if the car is lowered tho correct?
Old Mar 22, 2008 | 04:51 PM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: vtmustangs
Its fine if you have an adjustable UCA if you are worried about pinion angle.
It also matters how much lower that stock you are.
1" drop, an adj UCA is questionable.
2" drop, an adj UCA is recommended.
Old Mar 22, 2008 | 05:15 PM
vtmustangs's Avatar
vtmustangs
so then if the drop is like an inch or smaller then get adj lcas and be done with it
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Sep 30, 2015 10:13 AM
FivePointToTheOh
Sep 15, 2015 08:15 AM
JonnyBlazeGT
Aug 9, 2015 10:19 AM
