noisy shifter boot
I have a 05 it started to make noise around a thousand miles. It was driving me crazy, I brought to the dealer and they wanted to replace the throw out bearing and a bunch of other crap. Finally figure it out myself. It's that stupuid boot it's too tight and causes a rattle in the dash somewhere. When you slip the boot off it stop's making that noise. I have a bunch of other dash rattle's that I absoulutely hate. My biggest complaint about the car is the rattle's. And by the way I have had my car almost three years and this newby crap is a joke.........
ORIGINAL: jaguarking11
I had the same issue. Its just the material got stiff. It hapened to me when I used leather cleaner on it. I used the mguiars wipes. Worst product ever, its great for a show pice but it makes the interior look wet and the seats feel slipery and the dash blinds you in bright sunlight from the reflection. I actualy just cleaned it off with water on a lint free towel and worked the boot a bit. The noise is gone.
Its not the leather boot that squeeks.
Its the cabin sealing rubber boot below it.
Pull your shifter boot and trim off and see
all that rubbed off rubber stuff under there?
Thats coming from the rubber cabin sealing
boot. Lube it with some pure silicone (NOT WD40)
and the squeeking will be gone.
Mine was really bad. I installed my hurst shifter and made sure everything was tight when i installed it and now its quite. So idk what it was but i bet something was loose.
My mustang was fine until I added the PRO 5.0 shifter. It then would give a rattling humm betweem 3,000 to 4,000 RPMs. I fixed this issue during my Alpine install by adding dynamat extreme on top and underneath the surrounding shifter and E-brake areas. It WORKED!
[IMG]local://upfiles/86831/15FA0B33D20B4AD1B4771A07E977A7DC.jpg[/IMG]
junior04
Sep 28, 2015 10:53 AM
