wide band A/F - must buy or eye candy
#31
RE: wide band A/F - must buy or eye candy
Unless you know something about the duty cycle of your existing injectors, blindly throwing larger ones at the car isn't necessarily the answer either. You'll lose resolution in the lower rpm ranges, and injectors aren't at their best at 1.0 millisecond pulse widths to begin with.
Norm
Norm
#32
So my tune was worthless? I don't get why you posted this...
ORIGINAL: Norm Peterson
Norm
Norm
#33
Norm
Norm
#34
ORIGINAL: blueherd02gt
Norm
Norm
#35
"Overboard" is a good description regarding the injectors. And it's not the tune, at least not directly.
What I was getting at is that 60# injectors are so large for 4.6 liters worth of engine that you may very well end up with idle that's not entirely stable and give up some low speed/light throttle behavior. I don't see any point in making that kind of sacrifice if you aren't requiring at least 75% duty cycle from the larger injectors (given that the OE's would be completely inadequate). Pulse widths from the PCM aren't going to change from incrementing in 0.10 ms steps to 0.05 ms steps just because you installed injectors that have twice the flow. And if your OE injectors were working at 1.5 ms at idle, figure that the 60's would need to be down around 0.75 ms, which is below the level at which the operation of these things ends up in consistent fueling.
Norm
Norm
09-25-2015 06:30 PM
