Eibach Pro-kit
Old Mar 24, 2008 | 10:20 AM
gandyj's Avatar
gandyj
Default Eibach Pro-kit
I'm in the middle of installing the springs on the rear of my car but I can't tell which is the top or bottom of the new spring, can some of you who've done this tell me which is which?
Thanks
Joe
Old Mar 24, 2008 | 10:24 AM
schapman's Avatar
schapman
Default RE: Eibach Pro-kit
should be put in with the eibach labeling right side up.
Old Mar 24, 2008 | 11:06 AM
Tormentor's Avatar
Tormentor
Eibach Pro kit are the same as the Ford Racing springs and I had the same question. I called the speed shop I ordered them from and was told tight wound side goes up into body, this is the same orientation with the lettering right side up on the Ford Racing springs. Should be the same on the Eibach
Old Mar 24, 2008 | 01:54 PM
Tracedaddy's Avatar
Tracedaddy
I just installed them the same way the stock ones came out. (I don't remember anymore if the tightly wound side was up or down.) Look at the other side you haven't done and mimic that.
Old Mar 24, 2008 | 02:14 PM
gandyj's Avatar
gandyj
Schapman, Tormentor and Tracedaddy
Thanks for the responses even though I ended up doing it twice I got them installed.
The hardest part of the whole process was actually jacking up the car and putting the stands under it.
Now onto the fronts.
Thanks again.
drfister
May 3, 2018 10:38 PM
baddog671
Jul 26, 2016 01:20 PM
PullTab
Oct 30, 2015 08:46 AM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
RWHEELS
Sep 5, 2015 03:42 PM
