EASY, straight forward break in question?
Old Apr 11, 2005 | 07:13 PM
avanbroc's Avatar
avanbroc
Default EASY, straight forward break in question?
What RPM does Ford recommend to keep the engine under and for how long? I know that all of you have your own theories, but I want to know what the factory recommends. Thanks.
Old Apr 11, 2005 | 11:24 PM
dukenitro's Avatar
dukenitro
Default RE: EASY, straight forward break in question?
Did you read your manual?
Old Apr 12, 2005 | 12:30 AM
mtnmax's Avatar
mtnmax
I personally do not think RPM moderation is as critical as constantly changing the RPM (fast slow, fast slow). No cruise control for at least the first 1000 miles. And a good hard run through the gears every once in a while is a GOOD thing (for you AND the car).
Old Apr 12, 2005 | 02:02 AM
luv_the_stang's Avatar
luv_the_stang
heres the deal
first start hold at 2000 rpm to break in the cams for 2 mins
after about 20 miles
use 2rd gear and hit it hard from bout 2500 to just below redline and let off fast down to 2500 again
do this 10 times in a row and your rings are then seated
change oil at 500 then again at 1000 then 5000
motor should feel sweet after that
enjoy
Old Apr 12, 2005 | 02:15 AM
Tehrab's Avatar
Tehrab
duke what kind of rims are those? they rock
GimpyHSHS
Sep 18, 2015 12:27 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
