3rd Brake Light Question
Old Mar 26, 2008 | 10:21 PM
cegha's Avatar
cegha
Default 3rd Brake Light Question
Ok i just ordered the Smoked 3rd LED brake light from stangmods, and just went out to my car and installed it.
Now when the car is off and locked and everything, it appears as though the LED's are very dimly lit. As in power is still going to them after the car is off. Is this just something normal that they do or what's up?
I tested the brake light to make sure it works and it works properly, but with the car off it just seems as though there dimly lit. I just don't want my battery dead.
Is there possibly anything that i did wrong? I followed the tutorial on here for replacing one. It said that if the connector is in the wrong way it won't light up but mine lights up fine, so i don't know if i have it hooked up wrong and that is why it's doing that, or if it is just the way it looks with the car off.
Old Mar 26, 2008 | 10:30 PM
sailing220's Avatar
sailing220
Default RE: 3rd Brake Light Question
Are you sure they are dimly lit or are they maybe just reflecting some other light?
Old Mar 26, 2008 | 10:35 PM
wildboi013's Avatar
wildboi013
Ihave seen them glow a bit after turned off but hardly anytime... put your hands over it to see
Old Mar 26, 2008 | 10:45 PM
Mustang3GT07's Avatar
Mustang3GT07
[sm=ttiwwp.gif]
Old Mar 27, 2008 | 01:30 AM
cegha's Avatar
cegha
ORIGINAL: Mustang3GT07
[sm=ttiwwp.gif]
I knew this was coming. It could just be light reflecting inside the housing from my house when i looked at it, and it appeared dimly lit. I will try to get pics of it tomorrow night, like without a flash on or whatnot.
Old Mar 27, 2008 | 01:36 AM
Mustang3GT07
ORIGINAL: cegha
[sm=ttiwwp.gif]
Haha i had to do it. But its weird i know what your talking about because i bought some LED blue dome light bulbs and put them in. Ill be driving around the the dome light off of course but when u look up at it you can see the bulbs like glowing like there on. IDK if they are or not. Its like there on but super dim.
Old Mar 27, 2008 | 01:47 AM
PhattyDre16's Avatar
PhattyDre16
It's normal. A Light Emitting Diode still glows for a little even when the current isn't flowing. They don't work like lightbulbs so don't expect them to. I've heard of this before.
It's kinda like just turning off the tv and the pixels are still kinda lit up.
Old Mar 27, 2008 | 08:56 AM
jdmcbride's Avatar
jdmcbride
The circuit is either on or off with the factory bulb. You are simply connecting the LED array in place of the factory bulb, so the circuit is unaffected - still on or off. You areeither seeing a reflection off of the diodes or the residual power in the diodes after turning off. Either way, the circuit is off and will not drain your battery.
BTW, how do you like the Smoked 3rd LED Brake Light? I have one on order from American Muscle for my black GT.
Old Mar 31, 2008 | 08:42 PM
jdmcbride's Avatar
jdmcbride
ORIGINAL: jdmcbride
MINE DOES THE SAME THING!!! I just installed mine this evening. As soon as I plugged it up, the entire row of LEDs light up very dim. There is no reflection of light as i have the car in my garage with the lights off.
Cegha - What did you end up doing? I am going to call American Muscle tomorrow and see if they have heard of this and how to correct it.
Old Mar 31, 2008 | 08:47 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: cegha
[sm=ttiwwp.gif]
I know. It's like people sit around all day long just waitinf for a chance to post this thing. Use you imagination people.
