Last edit by: IB Advertising
Browse all: Ford Mustang Specifications & General Maintenance
- Ford Mustang V6 and Ford Mustang GT 2005-2014: How to Jack Up Your Car
Step by step instructions for do-it-yourself repairs.
where to put the floor jack
RE: where to put the floor jack
I agree and make sure you do not bend the diff cover in the process!!!!!!
ORIGINAL: odiaz
To be on the safe side, once you get the car jacked up, lower it onto jack stands. Don't leave the pumkin resting on the jack.
+1... if you're getting underneath the car make sure youeither use jack stands or put the tire(s) (that I assume you're going to remove in most of the cases where you gonna lift up the car) under the pinch rail(s) just in case. Also if you're going to use the pumpkin make sure to use a piece of wood or something because the differential cover can be easily damaged which can cause a potential leak
