Error CodE i never seeN
Old Mar 27, 2008 | 10:51 PM
Mustangansta's Avatar
Mustangansta
Default Error CodE i never seeN
Anyone have any clue as to what this code means - T0 340 cam pos - cs cir er 1s1 - my sct read this after i scanned because of a check engine light -
Old Mar 27, 2008 | 11:08 PM
marcuskeeler's Avatar
marcuskeeler
Default RE: Error CodE i never seeN
Isn't that a variable inlet timing issue?
Old Mar 27, 2008 | 11:11 PM
marcuskeeler
P0340 Camshaft Position Sensor circuit fault.
Does the car run ok?
Istill seem to remember somebody else having reported this code, it wassomething to do with the VCT Variable Camshaft Timing
Old Mar 27, 2008 | 11:46 PM
sailing220's Avatar
sailing220
If it has to do with Cam Position it can't be an error code that you want (are there any you do want? lol). But seriously, might want to have it checked out.
Old Mar 28, 2008 | 12:19 AM
mcgyvertech's Avatar
mcgyvertech
There's a sensor on the front of each head that detects cam position.(pg 303-14-5 workshop manual). There's also a Variable Camshaft Timing Oil Control Solenoid which regulates the oil pressure to the camshaft. Make sure these are plugged in and the wiring harnesses are intact. Beyond that, we have a warranty. Good luck.
Old Mar 28, 2008 | 11:13 AM
Mustangansta
wow sounds like a serious issue - - its running fine - same as usual - im thinkin if i should take to the dealer - i have an appointment with my dyno shop next week - thanks for the feedback -
06 GT- long tubes -hi flo cats - tune - 3:73's - JLT cold air - about 20k miles
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
ChampInSD
Oct 2, 2015 04:55 AM
