installing springs
RE: installing springs
I did my 01 and 07 without a compressor. You unbolt the spring from the top and when you drop assembly just make sure you have a buddy to catch the top portion so the bearings dont go everywhere... There's a how to video somewhere out there, let me see if I can dig it up.
ORIGINAL: aclass
I dont recommend it but what I did was backed the nut off to about half of the threads, taped the trigger down on my air gun with the socket on the nut, laid the fixture out in the grass and plugged the air hose in from about 15 ft away.
I did not use a spring compressor. I used a floor jack under the control arm and removed the large nut that holds the strut in. If you have a spring compressor you can remove the spring and strut as a complete assembly and disassemble it off the car.
ORIGINAL: aclass
ORIGINAL: aclass
ahahahhahahahaha
i cant stop laughing !
ORIGINAL: aclass
[sm=roll.gif] you made me forget what I was going to post now. Thats ok, just check out the tacobill how to mentioned.
