Clutch/Flywheel Recommendations
Whatdo you guys recommend for a clutch and flywheel setup on my car? Specs are in my sig. I was looking into getting a Fidanza Aluminum flywheel and a Spec Stage 3 clutch but I keep hearing you need to use their Flywheel. Any help is appreciated
RE: Clutch/Flywheel Recommendations
Spec 3+ is a good call.
You DON'T need their FW - u can even keep the stock one! I did. I have about 400 miles on it and am happy so far. its a little harsh at first however it broke in nicely. Pedal effort is easy but it is very aggressive in its engagement.
Well I am getting a flywheel but I think I'll end up getting the Fidanza one locally. How does it feel now that it is broke in? I'll probably just getting the Spec 3, not the 3+
it feels fine now that its broken in - it is grabby but can be feathered a bit. I strongly recommend the 3+ over the 3. the different design makes it much more street friendly from all I've read.
bradleyb
11-27-2015 07:50 PM
