Shaker 500 - CD ERROR
Old Apr 2, 2008 | 09:42 AM
Red_Stallion's Avatar
Red_Stallion
Default Shaker 500 - CD ERROR
So I just fired up the stang yesterday after de-winterizing her. Battery was actually dead this year for some weird reason, so after charging for a bit she fired up no problem.
I turned on the Shaker and went to play one of the 6 discs that I had loaded from last fall and when I try to play a CD it just says "CD ERROR".
I then tried to eject a disc and none of them would eject.
When I try to load a disc it just reads, 'SLOTS FULL'
I'm just out of warranty now so I would like to avoid a stupid bill from the stealership...if anyone has any ideas, muchly appreciated!!
Old Apr 2, 2008 | 11:14 AM
07torchgt's Avatar
07torchgt
Default RE: Shaker 500 - CD ERROR
same thing happened to me one day i just went inside and looked on the forum for something...about 15 minutes later went back out and the cd had been ejected.
Old Apr 2, 2008 | 11:38 AM
157dB's Avatar
157dB
Cut & Paste Expert
This happens with the Shaker after battery disconnection.
Allow the unit to cycle thru all 6 CDs before trying to eject
or load CDs.
Or you could do some onboard diags to figure out whats going on.
http://iihs.net/fsm/?dir=373&viewfil...o%20System.pdf
Old Apr 2, 2008 | 06:03 PM
davisr014's Avatar
davisr014
Mine is having the same problem the dealer has ordered a new one to replace it with. When mine had this problem I did some searching and several people have had the same issues.
Old Apr 2, 2008 | 06:30 PM
b1bendt's Avatar
b1bendt
I'd probably leave the battery on the charger for a while longer. Battery voltage may have been too low to operate the Shaker properly.
Old Apr 2, 2008 | 06:41 PM
boomer123's Avatar
boomer123
This happened to me about a week ago, i pulled radio out to hook up my gauges and get in there, and one of the plugs in the radio wasnt snapped all the way in when i put it back together. It took me a while to realize thats what it was, so i pulled the whole dash out again and replugged everything to the shaker 500 and it works perfect now.
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
zanemoseley
Sep 6, 2015 12:58 PM
