how do i do this???
Old Apr 3, 2008 | 10:25 AM
blkv6's Avatar
blkv6
Default how do i do this???
has anyone ever taken their exhaust off and cleaned it up? i have a plastic bag stuck under there and all the salt and crap from winter i want to get off too. any suggestions?
thanks
Old Apr 3, 2008 | 10:30 AM
SuperSonic05's Avatar
SuperSonic05
Default RE: how do i do this???
who going to look under there? I would just melt the bag off with a blowtorch, and go to a car was that does underbody.
Old Apr 3, 2008 | 10:36 AM
Nuke's Avatar
Nuke
I'm not sure why you need to remove it since you can get around it with a scotch-brite pad just about everywhere. But if you do want to remove it, it's all bolted clamps from the H-pipe back.
Old Apr 3, 2008 | 10:43 AM
blkv6's Avatar
blkv6
i need to take it off to fix a leak i have from when i put the duals on
Old Apr 3, 2008 | 11:12 AM
157dB's Avatar
157dB
Cut & Paste Expert
Paint it
[IMG]local://upfiles/69445/6AB423817CA044608FED601956EBF071.jpg[/IMG]
Old Apr 3, 2008 | 03:44 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
As Nuke stated - everything bolts off. But do be careful if you have a lot of salt corrosion, as you don't twist a bolt off.
That fact made it easy when I decided to install my IMCO Cherry Bombs Kit. It took me all of a couple of hours, and that included a couple of beer breaks!
Old Apr 3, 2008 | 08:44 PM
odiaz's Avatar
odiaz
ORIGINAL: 157db
Paint it
Cool, I was thinking of doing the same thing.
Old Apr 3, 2008 | 09:21 PM
JOHNNY's Avatar
JOHNNY
If the bag is melted on the exhaust just freeze the bag with the engine off and chip it off with a scraper. The spray you use to get dust off your keyboard or a can off freon works good.
Old Apr 3, 2008 | 09:27 PM
Kara's Avatar
Kara
It is easy to take off, just a couple of bolts, but you shouldnt have to take it off!
