Replaced plugs at 5,000 mles
Old Apr 4, 2008 | 08:40 PM
oshkoshbajawsh's Avatar
oshkoshbajawsh
I ♥ Acer
Default RE: Replaced plugs at 5,000 mles
i dont get why people are replacing them way before required service intervals anyway? why dont you just let the dealership pull them when need be and if something happens blame it on them..
Old Apr 4, 2008 | 09:23 PM
superslow's Avatar
superslow
I was completely unaware of the spark plug problem, I have about 23000 miles on my car. should i try and change the plugs or just leave them?
Old Apr 4, 2008 | 09:31 PM
doode's Avatar
doode
ORIGINAL: oshkoshbajawsh
if the plugs broke off, you can blame the dealer all you want, but i can gurantee you they won't be doing the labour of pulling your head off for free...design flaw or not
Old Apr 13, 2008 | 07:08 PM
mustangman03's Avatar
mustangman03
you dont have to pull the head off they make a tool that will pull the broken part out the 5.4, 4.6, and 6.8 if they are a 3 valve and their is any build up it can break off. The last plugs i pulled out was on a f 150 with 30,000 on it and 1 broke off. Its a B to get out also.
Old Apr 13, 2008 | 08:28 PM
Kara's Avatar
Kara
Crap mine has 50K miles. I guess time for a plug change? That would SUCK for them to break off[:@]
Old Apr 13, 2008 | 08:38 PM
8178A's Avatar
8178A
ORIGINAL: Kara
They really don’t break off. The metal case of the original plug is a two piece unit with the lower tip part held into the upper part by a swedge around the lower part. When the lower part gets stuck in the head it just pulls loose from the upper part as the plug is unscrewed. The Champion plug is a one piece unit.
Old Apr 13, 2008 | 08:49 PM
pat123's Avatar
pat123
Does this problem apply to the V6 as well?
Old Apr 13, 2008 | 08:59 PM
one eyed willy's Avatar
one eyed willy
what about the autolites?any one tried them,are they all one piece like the champions?
Old Apr 13, 2008 | 09:02 PM
8178A's Avatar
8178A
ORIGINAL: one eyed *****
They are two piece.
Old Apr 13, 2008 | 09:12 PM
jmk3's Avatar
jmk3
Dagastino racing has them in stock for about $17 they had them to me in about 3 days. Haven't put them in yet. The gaps were all over the place I've regapped them.
In response to several comments, I wouldn't hold my breath for many aftermarket plugs cause Ford changed the plug design so they only will fit a couple of years.
It won't be Fords problem because your waranty will be up when they are due to be changed at 100,000 miles, it will be your problem.
Ford charges $125.00 per broken plug to remove with their tools (head left on) another forum member broke one off then had it towed to dealership where they broke 4 more with a total of 5 removed at $125.00 ea. plus 8 new plugs at $10.00 ea. ouch!
I don't know who has more blame Ford or Autolite for making the crimped together 2 piece plug.
