removal question
Old Apr 8, 2008 | 08:20 AM
1morepart's Avatar
1morepart
Default removal question
what do i use to remove the "stealership" sticker on the back of my gt....i've heard a heat gun. but what will remove that sticky crap left over and not damage the paint?
Old Apr 8, 2008 | 08:22 AM
ink003's Avatar
ink003
Default RE: removal question
i've seen it done with some elbow grease and a bowl of very hot water. soak a clothin the water, hold it on the sticker, and scrape.
Old Apr 8, 2008 | 08:23 AM
truckstoy's Avatar
truckstoy
Goo-Gonewill do the trick
Old Apr 8, 2008 | 08:27 AM
157dB's Avatar
157dB
Cut & Paste Expert
I peeled mine letter by stinkin letter with an exacto knife
and thumbnails. If you are very careful you can do it
without even touching the paint.
Get the vinyl to lift by getting it right at the edge with
the sharp point of the knife and lift the corner. Then
continue lifting and peeling with your fingernails.
Those guys that let the Stealership remove it by saying
"I am not buying with that on there" dont see just how its
removed with harsh chemicals and elbow grease by the wash jocky. [:@]
Old Apr 8, 2008 | 08:28 AM
BlackStang21's Avatar
BlackStang21
[align=left]I used 3M adhesive remover. Just sprayed it on the sticker with a towel underneather to catch any run off. After about a minute of allowing it to sit the letters would peel off. Had to spray a couple of times to get the whole sticker off but it removed the adhesive that was left over.
[/align]
Old Apr 8, 2008 | 08:45 AM
jdphillips73's Avatar
jdphillips73
I told em i wouldnt buy the car unless it was removed first
Old Apr 8, 2008 | 08:57 AM
cbrstng08's Avatar
cbrstng08
I took mine off the same day i bought it. All i did was get a towel and a screwdriver, used the towel to leverage the screwdriver against without touching the paint and slowly started prying a corner and it popped right off. No paint damage, no left over residue, and took all of 1 minute.
Old Apr 8, 2008 | 09:30 AM
GidyupGo's Avatar
GidyupGo
I used a hair dryer. I heated it and gently pulled it off with my fingers. Most of the glue came off with the sticker, and when it cooled, I was able to just rub the rest of the glue, again with my fingers and it sort of balled up and I picked it off.
Old Apr 8, 2008 | 09:47 AM
jahudso2's Avatar
jahudso2
I just used my thumb nail to get the letters off and then goo-gone to get the sticky stuff off. Worked like a charm.
Old Apr 8, 2008 | 09:54 AM
Ford_Dude's Avatar
Ford_Dude
I just let my finger nails grow for a couple weeks then used my nails to pry it off then next few times I washed it I spend more time on that spot
