08 gt auto rev limiter
RE: 08 gt auto rev limiter
ORIGINAL: SilverGT300
whats up guys i just bought an 08 gt.
when i put in neutral and rev it it stops at about 5000 rpms
my moms 06 gt convertible lets rev it all the way? its an auto as well
any 08's expierence this
NEVERrev your engine unless it is at operating temperature. Make sure the little needle that shows coolant temp is exactly in the middle between hot and cold before you sit there and rev the living h3ll out of your car.
if you rev cold then you risk engine damage due to not being fully lubricated
sure oil has fully circulated after a couple sec but its not heated yet so its thicker and hasn't gotten to the narrower places
you might not notice it from once or twice but if you keep doing it then your "playing with fire"
the tighted spots aren't fully lubed yet so they could take damage
(connecting rod on the crank)
(main bearings)
ect
(main bearings)
ect
