Maintenance Schedules?
I was looking at our maintenance schedules and it looked pretty vague, so I put together a more detailed set (based on other sources, e.g. Car Care Council, Ford Fleet Maintenance, etc. and including our maintenance pamphlet) ... What do you think? I designed it towards Severe Service (mostly stop-and-go city driving):
Inspect tires & tire pressure - every week
Inspect all lights - once a month
Motor oil + filter - every 3,000mi or 3 months or 200 hours of engine operation
Lubricate Lower Control Arm + Steering Linkage Ball Joints w/Zerk Fittings - every 3,000 miles or 3 months
Rotate & inspect Tires & wheel end-play and turning noise - every 3,000 miles or 3 months
Multi-point inspection - every 3,000 miles or 3 months
Check battery charge + electrolyte level - every 3,000 miles or 3 months
Inspect Brake System - every 5,000 miles or 6 months
Parking Brake Adjustment - every 7,500 miles or 6 months
Check and replace (if necessary) all window wipers - every 6 months
Transmission fluid - every 15,000 miles or 12 months
Coolant - every 15,000 miles or 12 months
Fuel Filter - every 1 year or 15,000 miles
Inspect & lubricate all non-sealed steering linkage, ball joints, suspension joints, half and drive-shafts and u-joints - every 1 year or 15,000 miles
Air Filters - clean or replace once a year
Brake fluid change every 2 years or 30,000 miles
Spark Plug Replacement - every 2 years or 30,000 miles
Change Transaxle Fluid - every 2 years or 30,000 miles
Lubricate Front Wheel Bearings, Replace Grease Seals, Adjust Bearings - every 2 years or 30,000 miles
Change Transfer Case Fluid - every 2 years or 30,000 miles
Inspect complete exhaust system and heat shields - every 2 years or 30,000 miles
PCV Valve - every 2 years or 30,000 miles
Timing Belt Replacement - every 3 years or 48,000 miles
Power steering fluid change - every 3 years or 48,000 miles
Change rear axle lubricant; non-synthetic only - every 5 years or 75,000 miles
RE: Maintenance Schedules?
You might have trouble changing the "timing belt every 3 years". Let me know whenyou find it.
EDIT: while you`re under there, keep a sharp eye out for that "transaxle" Might as well look for the "transfer case" too.
Overkill. Tire pressure once a month unless you have a know problem. Rotate every 5000 miles. Any sooner is crap. How do I crack open the battery? Don't use my parking brake, (ever), WAY overkill on the tranny fluid and coolant, brake fluid every 3 years, crap I'm tired of looking. Just follow the freaking book.
ORIGINAL: SumterBoy
The guy at the Stealership said to change your Air Filter every 3000 miles, he said that the manual stated 5000 miles.
