Getting a new rattle.........
Old Apr 9, 2008 | 02:00 PM
GidyupGo's Avatar
GidyupGo
Default Getting a new rattle.........
somewhere under the driver's side I think. I got under there and checked everything and can't find anything that jumps out at me. It sounds like an aluminum pie pan vibrating. I saw the heat shields and kind of bent them a little to see if they were touching something but it is still there. It only happens right when the tranny is a bout to shift under moderate acceleration and then it stops after the shift. One of those things that drive you crazy.
Old Apr 9, 2008 | 02:07 PM
thewarmachine's Avatar
thewarmachine
Default RE: Getting a new rattle.........
Do you have a stock midpipe?
Are your exhaust hangers contacting the transmission crossmember?
Old Apr 9, 2008 | 04:30 PM
pascal's Avatar
pascal
S197 Section Modder-ator
One of your tooth filling is getting loose.
Old Apr 9, 2008 | 04:32 PM
MD07gtcs's Avatar
MD07gtcs
That sux hope you can find it.
Old Apr 9, 2008 | 04:35 PM
Riptide's Avatar
Riptide
I feel your pain. The dealership fixed a rattle coming from my rear parcel shelf area. Took them like 3 days to do it in their body shop. They did it under warranty. Today I swear I'm starting to hear that noise come back again. It's not as bad as it was - yet. Guess I'll coast for a while and if it starts to get worse back the car goes again.
Old Apr 9, 2008 | 04:43 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: GidyupGo
Sounds like the catalytic converter shield is vibrating against the body of the converter itself. Happened onthe aftermarket exhaust on my 00.
Put the tranny in nuetral and see if you can rev the engine to make it rattle. If weld joing is coming loose or weakened/cracked you would get sufficient vibration but would be hard pressed to actually "feel" it by hand.
Old Apr 9, 2008 | 04:54 PM
badger2840's Avatar
badger2840
Getting a rattle fixed at the dealership is like sandblasting your teeth in the morning with gravel.They dont know Sh$t most of the time. I sent mine in for a rattling rear decklid and they changed both my rear speakers ?!?!?!?!? I was like wtf.
Still a rattle but 2 new speakers out back .
Dealership mechanics are like lab chimps, they work with repitition. If its something they havent seen , good luck !
