Pypes mid-muffler system install advice
Has anybody installed the pypes mid-muffler system themselves and can offer me any advice? I've heard that there are really tight tolerances, the resonators almost come into contact with the fiberglass on the fuel tank. If it's too much of a PITA I'd rather just take it to a local exhaust shop. I only have jacks, rampsand jackstands available at home to do the work. I don't want to get halfway through the project and have to get it towed somewhere to finish. I haven't had to do that yet (knock on wood) with all of my other upgrades. I've installed the off-road h-pipe and several axle-back systems but I hear that getting the exhaust tube from around the rear axle on my current setup which is all one pipe (unlike the pypes system which comes apart in pieces), can be a real problem. Now if I just had a lift it would be a piece of cake.
Any thoughts/experiences appreciated.
[IMG]local://upfiles/73912/409069C157AE4125BD1337799F185E41.jpg[/IMG]
Yeah, I've seen his videos and that was one of the factors pushing me towards the Pypes setup. It looks like he does his work off ramps/jackstands too so that would be great advice. I'll PM him if he doesn't notice this post. Thanks!
I installed the system on mine last year & did a write-up on it. Do a search & you'll find lots of info on it.If you don't have a lift, you'll need to unbolt the lower ends of the rear shocks, jack the car up more to get the factory over-axle pipeoff.
The hangers on the last pipe on pass side don't fit well & will either need heated up & bent or removed & rewelded on.
Fitment is tricky & might take a few tweaks to align everything up correctly. If you've got the money & don't mind other people working on your car, you might just want a shop to do it.
When you said "unbolt the rear shocks" you made my mind up. I don't feel like cursing my way through trying to get that axle hump pipe out of there. Thanks.
ORIGINAL: hammeron
moosestang installed this system and
shouldbe checking in soon
Hey!@ I didn't get a cool hat or any stickers! It is not that hard to install. the hardest part is removing the stock over axle pipes. You'll need to get the back up pretty high and unbolt the shocks to let the rear axle hang. I had to get all 4 corners up off the ground in order to get the stock pipes out. Someone said removing the rear tires would aid in removing the pipes.
Lining up the tips can be a hassle. I had to heat up the passenger side rear most hanger and bend it with a hammer to get it the way I wanted.
Clearance with the gas tank is not an issue. I did have some clearance issues with my passenger side hangers touching the hanger brackets when the exhaust warmed up and the drivers side over axle pipe hitting the panhard bar brace on large bumps. It sounded like a cricket when you stepped on it and would rattle occasionally. I fixed that by removing the hangers and grinding off some of the material where it rubbed. I also widened the bolt holes in the hangers to make them slide back. For the drivers side pipe you need to push up on the connection and hold it while you tighten the clamp. that should get you enough clearance. I'd still like my tips a little higher and the drivers side needs to be straightened some, but it's good enough for government work as they say. There's a good how to on www.americanmuscle.com
They sound great!
LOL!! yeah,the hat and stickers were the best part. ha! Thanks for the info. I think I'll call my local tuner and just have them do it if they have time tomorrow. They can do the heating and banging while I'm at work. I may just have them do another dyno tune while they're at it. I haven't had one since I bought the car and had the original catted exhaust. I know I'm in dire need of a tune with all the exhaust mods I've done...
That's a great look from behind the car moose. I could have sworn your car was striped!? I'm going to have them mount up the mid-mufflers and then put my MAC's back on. I love the chrome finish and deepness of the MAC's but hate the trumpet at 2.5-3k rpm with the off-road pipe. Hoping the mid-muff/resonators will kill it. We'll see how it sounds. At least I can remove the MAC's and put the Pypes tips back on later myself. I think the MAC's look really good under the rear:
[IMG]local://upfiles/73912/F920E6A956574C50A7788D4A41898F9F.jpg[/IMG]
I've saved so much money doing things myself too
