Throttle Response Fix?
Old Apr 11, 2008 | 04:33 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Default RE: Throttle Response Fix?
CAI+TUNE
Old Apr 11, 2008 | 04:36 PM
thewarmachine's Avatar
thewarmachine
It's not a throttle response fix. That's what a tune is for. It's to get rid of the dead space in the actual physical pedal.
Old Apr 12, 2008 | 03:33 AM
Orion_240's Avatar
Orion_240
that dead space is really getting to be a pain!
I experimented with it today while driving through the parking structure at work. Going just over 10 mph I could tap repeatedly on the gas pedal yet nothing would happen! RPMs wouldn't change at all. I should probably film it to see but I am pressing the pedal down a little, not just hitting it.
The delay makes driving slow a real PITA, and pulling out slowly into the alley or street becomes more difficult. With hand controls I could probably be more precise but it hard to do that with my foot. I wonder if the automatic makes it even harder?
Old Apr 12, 2008 | 05:01 AM
NJBLK07GT's Avatar
NJBLK07GT
Anyone have any pictures of the "Stop Screw Mod"? I'm interested in this fix.
Thanks
Old Apr 12, 2008 | 05:44 AM
Daniel60's Avatar
Daniel60
Now If I could have that guy come over to my house and do those 10 or more steps.
Old Apr 12, 2008 | 08:24 AM
MTAS's Avatar
MTAS
ORIGINAL: whtcanbrwnd04u
CAI+TUNE
For the electronic sluggishness, yes. But for the physical delay clearly indicated in the pics above, no tuner will get rid of that.
Old Apr 12, 2008 | 08:29 AM
GT John's Avatar
GT John
Yup.
It is not throttle response, that's a tuning issue.
What they are referring to is the "dead space". This is demonstrated by laying your foot on the gas pedal, then pushing down on the pedal to a point that the engine actually starts to rev.
The way I corrected mine was to cut a small piece of 1/8" +/- aluminum and bend about a 45 deg. angle on it and tape it in position.
If you can squeeze yourself into a position to see the action of the gas pedal you will notice that you can depress the gas pedal, by hand, and see the space where the aluminum spacer goes into.
You will have to run your car through a few start cycles to get the PCM to learn the new throttle position.
Works great. I have neither the eyes of a buzzard nor the hands of a brain surgeon to perform the other mod which on face value seems pretty simple.
Old Apr 12, 2008 | 10:09 AM
NJBLK07GT's Avatar
NJBLK07GT
Anyone have a picture of this done? Sounds easy to do but you know what they say, "a picture is worth a thousand words".
Old Apr 12, 2008 | 10:35 AM
wingman75's Avatar
wingman75
ORIGINAL: Orion_240
I have an auto and when I try to accelerate slowly away from a stop with other traffic I end up being the last one away or I burn rubber if I push a little to much on the gas pedal (I have 3.73 gears which don't help this situation).
Old Apr 12, 2008 | 10:41 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: GT John
Or you can calibrate it with the PCM right away by
turning the key to ON without starting the engine.
Allow the idiot lights to go out. Press the gas pedal
slowly all the way down, hold it there for a sec and
release it slowly. Do this a few times. Turn off the key
and its now calibrated to the PCM.
Everyone should do this regardless of doing the mod or not.
