Sponsored by:
Sponsored by:
Redline RPM
Old 04-16-2008, 10:53 AM
Grabber
Grabber's Avatar
Default RE: Redline RPM
Mine goes up to 7000 give or take. But, my Centri gets more and more power at the higher RPM's, it doesn't drop.
Grabber is offline
Old 04-16-2008, 11:13 AM
VaBeachMustang
VaBeachMustang's Avatar
ORIGINAL: Grabber
Yup,keeps climbing like the price of gasoline!
VaBeachMustang is offline
Old 04-16-2008, 11:33 AM
TheDutchTexan
TheDutchTexan's Avatar
No, upping the revlimit is NOT safe. Your internals are balanced to endure a safe redline as set by a car manufaturer. Any revs over that will increase the forces they have to endure, thus enhancing the chances something will break.
A little imperfection can turn to kilograms of imperfection given enough rotation. Your internals will not like that one bit. Enhance all you want, it's your car, but if you did not touch the internals, do not touch the revlimiter.
TheDutchTexan is offline
Old 04-16-2008, 11:51 AM
Riptide
Riptide's Avatar
The stock redline is what, 6200?
Riptide is offline
Old 04-16-2008, 11:52 AM
Riptide
Riptide's Avatar
Riptide is offline
Old 04-16-2008, 12:01 PM
exx1976
exx1976's Avatar
I think 6250.
I think 6250.
exx1976 is offline
Old 04-16-2008, 12:04 PM
Riptide
Riptide's Avatar
I had no idea tuners were upping the rev limit. I have a 91 octane tune and JLT2 on the way from brenspeed. Will their tune up my rev limiters? If so I'm not sure that I'm real crazy about that..
Riptide is offline
Old 04-16-2008, 12:17 PM
Going for broke
Going for broke's Avatar
no point in being much above 6000 IMO. and yes more r's = more chance of engine failure.. thats simple physics.
Going for broke is offline
Old 04-16-2008, 04:46 PM
howarmat
s197 Junkie
howarmat's Avatar
you all are wrong actually.....you can set the engine to 7k and it wont hurt the car.......what really matters is how often you go into that range.
The car will start pulling timing a couple hundred before the limiter. Technically yes going up a little in the value is going to be more stressful on the the engine. Anyone who actually races knows that they need to raise the limiter for decents times. Depending on you gear setup, you get ****ed by having to shift once more right before the line cause 6250 isnt enough.
you are plenty safe upping it a couple hundred RPM.....just dont bouce the car off the limiter to often.
howarmat is offline
Old 04-26-2008, 06:48 PM
MikeD916
MikeD916's Avatar
So in a stock setup when you reach redline, the car prevents you from going over no matter how hard you hit the gas? Kinda like an engine safety feature?
MikeD916 is offline
Quick Reply: Redline RPM
